Go to https://SERVER_URL:8090/IncrementalBackups/createBackup
and click on Select Website
dropdown and post screenshot here
Personally that feature only worked for me on my fork.
There’s quite a few things that break it easily, sometimes you need to first connect from machine A to machine B to have the fingerprint set up, firewall issues, etc.
What I started doing now is this, check if you have luck with it:
Environment:
Machine A → Has the current website
Machine B → Where I want to migrate website to
Steps:
Machine A:
- Go to cyberpanel → Backup → Create Backup → Select Website → Destination Home
- Download the generated tar.gz file located at
/home/WEBSITE_URL/backup/
into your computer
Machine B:
- Upload the tar.gz downloaded in the step above into the folder
/home/backup/
. Example:/home/backup/backup-mywebsite.com-10.26.2022_10-38-40.tar.gz
- Go to cyberpanel → Backup → Restore backup → Select the file you uploaded → Restore
NOTE: Your website CAN NOT exist at the machine B. This method will recreate all the files, dns, database, settings, etc
Edit: You may need to re-issue your SSL after you restore the website
just show me that password auth is enabled on both servers?
