Build process completed successfully
Installing ‘/usr/local/lsws/lsphp74/lib64/php/modules/zip.so’
install ok: channel://pecl.php.net/zip-1.19.0
configuration option “php_ini” is not set to php.ini location
You should add “extension=zip.so” to php.ini
CyberPanel Successfully Installed
Current Disk usage : 6/40GB (16%)
Current RAM usage : 293/4096MB (7.15%)
Installation time : 0 hrs 18 min 33 sec
Visit: https://IP:8090
Panel username: admin
Panel password: 1234567
WebAdmin console username: admin
WebAdmin console password: oWt2td7UcCyCcOY3
Run cyberpanel help to get FAQ info
Run cyberpanel upgrade to upgrade it to latest version.
Run cyberpanel utility to access some handy tools .
Website : https://www.cyberpanel.net
Forums : https://forums.cyberpanel.net
Wikipage: https://docs.cyberpanel.net
Enjoy your accelerated Internet by
CyberPanel & OpenLiteSpeed
If your provider has a network-level firewall
Please make sure you have opened following port for both in/out:
TCP: 8090 for CyberPanel
TCP: 80, TCP: 443 and UDP: 443 for webserver
TCP: 21 and TCP: 40110-40210 for FTP
TCP: 25, TCP: 587, TCP: 465, TCP: 110, TCP: 143 and TCP: 993 for mail service
TCP: 53 and UDP: 53 for DNS service
Would you like to restart your server now? [y/N]: y
Now i am unable to login with root on ssh, server is on what to do, no cyber panel working
