CSF is not installing after upgrade to CyberPanel 1.7
Main Log File
[09-19-52-Sun-Dec-2018] No JSON object could be decoded
[03-57-40-Mon-Dec-2018] Trying to obtain SSL for: panel.rkmultispeciality.com and: www.panel.rkmultispeciality.com
[03-57-52-Mon-Dec-2018] Failed to obtain SSL for: panel.rkmultispeciality.com and: www.panel.rkmultispeciality.com
[03-57-52-Mon-Dec-2018] Trying to obtain SSL for: panel.rkmultispeciality.com
[03-57-57-Mon-Dec-2018] Successfully obtained SSL for: panel.rkmultispeciality.com
[05-20-07-Mon-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[05-20-18-Mon-Dec-2018] [Errno 2] No such file or directory: ‘csf.tgz’ [CSF.run]
[05-56-06-Mon-Dec-2018] No JSON object could be decoded
[05-56-26-Mon-Dec-2018] No JSON object could be decoded
[05-56-48-Mon-Dec-2018] No JSON object could be decoded
[05-56-55-Mon-Dec-2018] No JSON object could be decoded
[06-00-17-Mon-Dec-2018] No JSON object could be decoded
[06-00-29-Mon-Dec-2018] No JSON object could be decoded
[06-24-26-Mon-Dec-2018] [u’top’, u’-’, u’18:24:26’, u’up’, u’3’, u’days,’, u’23:41,’, u’0’, u’users,’, u’load’, u’average:’, u’0.00,’, u’0.02,’, u’0.00\
[06-24-30-Mon-Dec-2018] [u’top’, u’-’, u’18:24:30’, u’up’, u’3’, u’days,’, u’23:41,’, u’0’, u’users,’, u’load’, u’average:’, u’0.00,’, u’0.02,’, u’0.00\
[06-24-33-Mon-Dec-2018] [u’top’, u’-’, u’18:24:33’, u’up’, u’3’, u’days,’, u’23:41,’, u’0’, u’users,’, u’load’, u’average:’, u’0.00,’, u’0.02,’, u’0.00\
[06-24-37-Mon-Dec-2018] [u’top’, u’-’, u’18:24:37’, u’up’, u’3’, u’days,’, u’23:41,’, u’0’, u’users,’, u’load’, u’average:’, u’0.00,’, u’0.02,’, u’0.00\
[06-24-40-Mon-Dec-2018] [u’top’, u’-’, u’18:24:40’, u’up’, u’3’, u’days,’, u’23:41,’, u’0’, u’users,’, u’load’, u’average:’, u’0.00,’, u’0.02,’, u’0.00\
[06-24-44-Mon-Dec-2018] [u’top’, u’-’, u’18:24:44’, u’up’, u’3’, u’days,’, u’23:41,’, u’0’, u’users,’, u’load’, u’average:’, u’0.00,’, u’0.02,’, u’0.00\
[06-24-47-Mon-Dec-2018] [u’top’, u’-’, u’18:24:47’, u’up’, u’3’, u’days,’, u’23:41,’, u’0’, u’users,’, u’load’, u’average:’, u’0.00,’, u’0.02,’, u’0.00\
[06-24-51-Mon-Dec-2018] [u’top’, u’-’, u’18:24:51’, u’up’, u’3’, u’days,’, u’23:41,’, u’0’, u’users,’, u’load’, u’average:’, u’0.00,’, u’0.02,’, u’0.00\
[06-24-54-Mon-Dec-2018] [u’top’, u’-’, u’18:24:54’, u’up’, u’3’, u’days,’, u’23:41,’, u’0’, u’users,’, u’load’, u’average:’, u’0.00,’, u’0.02,’, u’0.00\
[06-24-58-Mon-Dec-2018] [u’top’, u’-’, u’18:24:58’, u’up’, u’3’, u’days,’, u’23:41,’, u’0’, u’users,’, u’load’, u’average:’, u’0.00,’, u’0.02,’, u’0.00\
[07-00-34-Mon-Dec-2018] No JSON object could be decoded
[07-04-49-Mon-Dec-2018] No JSON object could be decoded
[07-05-33-Mon-Dec-2018] No JSON object could be decoded
[07-05-46-Mon-Dec-2018] No JSON object could be decoded
[07-10-20-Mon-Dec-2018] No JSON object could be decoded
[07-10-33-Mon-Dec-2018] No JSON object could be decoded
[07-32-31-Mon-Dec-2018] Failed to apply rule: sudo firewall-cmd --permanent --zone=public --add-rich-rule=‘rule family=“ipv4” source address=“139.59.47.175” port protocol=“tcp” port=“7080” accept’ Error #252
[07-33-30-Mon-Dec-2018] Failed to apply rule: sudo firewall-cmd --permanent --zone=public --remove-rich-rule=‘rule family=“ipv4” source address=“139.59.47.175” port protocol=“tcp” port=“7080” accept’ Error #252
[07-35-05-Mon-Dec-2018] Failed to apply rule: sudo firewall-cmd --permanent --zone=public --add-rich-rule=‘rule family=“ipv4” source address=“139.59.47.175” port protocol=“tcp” port=“7080” accept’ Error #252
[07-37-32-Mon-Dec-2018] Failed to apply rule: sudo firewall-cmd --permanent --zone=public --remove-rich-rule=‘rule family=“ipv4” source address=“139.59.47.175” port protocol=“tcp” port=“7080” accept’ Error #252
[07-38-39-Mon-Dec-2018] No JSON object could be decoded
[09-41-13-Tue-Dec-2018] No JSON object could be decoded
[10-20-17-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-22-11-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-22-35-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-24-19-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-24-53-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-28-28-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-30-00-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-38-37-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-39-55-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-41-53-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-43-00-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-44-21-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-57-32-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[10-58-17-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
[11-03-23-Tue-Dec-2018] Command ‘[‘sudo’, ‘cat’, ‘/etc/csf/csf.conf’]’ returned non-zero exit status 1[fetchCSFSettings]
