Provider: Digital Ocean
Virtualization Type: KVM
System: Ubuntu 18.04
Installation option:
OLS or Enterprise?
OLS
official
no
yes
Install LiteSpeed Memcached?
yes
Install Memcached?
yes
yes
Install Redis?
yes
Problem:
I added a cron job on the CyberPanel. The job is created to /var/spool/cron/[username], but not appears on the Cyber Panel Cron Management list, and not running.
The command looks like this: php /home/[domain]/public_html/script.php
PHP file owned by user, chmod 777.
Please help! Thanks!
Info: The Cyber Panel is a fresh install, latest version 1.9.2.
Someone? Nobody knows the solution?
If I modify the cronPath on the cronUtil.py, the listing is works fine.
def getWebsiteCron(externalApp):
try:
if ProcessUtilities.decideDistro() == ProcessUtilities.centos:
cronPath = "/var/spool/cron/" + externalApp
else:
cronPath = "/var/spool/cron/crontabs/" + externalApp
I removed crontabas/ in else branch.
Now looks like this:
try:
else:
However, cron tasks will not run.
What’s the real problem? What is not configured well?
On AddNewCron function is missing the operating system test on CronPath:
def addNewCron(externalApp, finalCron):
try:
CronPath = ‘/var/spool/cron/%s’ % (externalApp)
with open(CronPath, "a") as file:
file.write(finalCron + "\
This part seems to be quite problematic under Ubuntu.
