I use the ‘cyberpanel admin > website > cron jobs’ to add a list of cron jobs for a specific website and they do not run. If I add them using crontab -e and they work fine. It appears the admin panel is not running the cron jobs.
I’m running version 1.8.1 on Ubuntu via DigitalOcean.
Cron jobs added from CyberPanel runs as a website user, so may be due to permissions it is not running.
Make sure the command runs as the website user. You can find website user using ls -la /home and then do su user and try to run your cron command and see if there are any permission issues.
