Hello @usmannasir @CyberPanel my control panel always loading and loading inside /home/cyberpanel/error-logs.txt its said [Errno 111] Connection refused
Can someone give me advice?
Thank you
i have same problem. can anyone help me about that ?
maximum recursion depth exceeded while calling a Python object
[03.24.2022_11-09-03] [Errno 111] Connection refused
I hope you have upgraded cyberpanel recently because there are many bug fixes done. If not, please do it.
I upgraded to the latest version. However, I still can’t do many things. for example php myadmin won’t open and gives 404 error. or adding a new website. or I can’t change the version in managephp/editPHPConfigs
what can i do.
here is my upgrade code :
Can you please update again seem update didnt done properly
