Hello! Is CloudLinux Fresh install supported using the CloudLinux ISO? Or do we need to install CentOS, install CyberPanel, then convert it to CloudLinux?
Basic CloudLinux Server Install with no changes after install except yum upgrade
Provider: Locally Hosted Dev Image
Virtualization Type: KVM
System: CloudLinux 7.8
Installation option: all the default
OLS or Enterprise?
both have same issue
official
Memcached extension and backend?
yes
Redis extension and backend?
yes
Problem:
Error: Package: git-core-2.17.0-1.el7.lux.x86_64 (CyberPanel)
Requires: libpcre2-8.so.0()(64bit)
Error: Package: git-2.17.0-1.el7.lux.x86_64 (CyberPanel)
Requires: libsecret-1.so.0()(64bit)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
No package telnet available.
No package libevent-devel available.
No package gcc available.
No package libattr-devel available.
No package xz-devel available.
No package gpgme-devel available.
No package curl-devel available.
No package openssl-devel available.
Error: Package: 3:mariadb103-devel-10.3.21-2.el7.ius.x86_64 (CyberPanel)
Requires: openssl-devel
Error: Package: python36-devel-3.6.8-2.el7.ius.x86_64 (CyberPanel)
Requires: python3-rpm-macros
Error: Package: 3:mariadb103-common-10.3.21-2.el7.ius.x86_64 (CyberPanel)
Requires: mariadb-libs(x86-64) < 1:10
Removing: 3:mariadb-libs-5.5.65-1.el7.cloudlinux.x86_64 (@anaconda/7.8)
mariadb-libs(x86-64) = 3:5.5.65-1.el7.cloudlinux
Obsoleted By: MariaDB-shared-10.1.46-1.el7.centos.x86_64 (CyberPanel)
mariadb-libs(x86-64) = 1:10.1.46-1.el7.centos
Available: 1:mariadb101u-libs-10.1.41-1.el7.ius.x86_64 (CyberPanel)
mariadb-libs(x86-64) = 1:10.1.41-1.el7.ius
Requires: redhat-rpm-config
command failed, exiting…
[root@cyberpanel-cloudlinux-dev ~]#
