Hi!
We changed our OS to cloudlinux, and if we try to install cyberpanel, get an error… (error log attached)
I reinstall the whole system like 2-3 times, fresh install and I’am in su and I runned the yum update as well. For sadly its not solved the problem…
Any tipp? We need that server with shortest time as possible…
Starting main installation..,30
[05.01.2022_12-18-31] Starting CyberPanel installation..,10
[05.01.2022_12-18-31] Running: yum install sudo -y,10
[05.01.2022_12-18-34] Successfully ran: yum install sudo -y.,10
[05.01.2022_12-18-34] Running: useradd -s /bin/false cyberpanel,10
[05.01.2022_12-18-34] [ERROR] We are not able to run useradd -s /bin/false cyberpanel return code: 9. Fatal error, see
$[05.01.2022_12-18-34] [ERROR] We are not able to run useradd -s /bin/false cyberpanel return code: 9. Fatal error, see
$[05.01.2022_12-18-35] [ERROR] setup_account_cyberpanel. 71, see /var/log/installLogs.txt for full details.
[05.01.2022_12-18-35] Running: rpm -ivh http://rpms.litespeedtech.com/centos/litespeed-repo-1.2-1.el7.noarch.rpm, see /
$[05.01.2022_12-18-36] [ERROR] We are not able to run rpm -ivh http://rpms.litespeedtech.com/centos/litespeed-repo-1.2-1
$[05.01.2022_12-18-36] [ERROR] We are not able to run rpm -ivh http://rpms.litespeedtech.com/centos/litespeed-repo-1.2-1$
Oops, something went wrong... [404]
