Where can I set a different SSLCipherSuite value? I see it’s under /conf/httpd.conf, but this file says is autogenerated and any custom changes will be overwritten.
So where can I enter my own ciphers for the webserver?
Thanks,
George
Thanks,
George
login to webadmin console [Tutorial] How to setup and login to OpenLiteSpeed webadmin console - Blog Posts - CyberPanel Community
go to listener and vhost configuration , in SSL tab , you will see an option box to configure ciphersuit.
Best regards,
I’m running CyberPanel Enterprise which doesn’t come with OLS, but with LiteSpeed Enterprise. There’s no option to set the ciphers in the webadmin console there. It supposedly reads the configuration from /usr/local/lsws/conf/httpd.conf
Any other ideas?
-G.
@George said:
Hello,I’m running CyberPanel Enterprise which doesn’t come with OLS, but with LiteSpeed Enterprise. There’s no option to set the ciphers in the webadmin console there. It supposedly reads the configuration from /usr/local/lsws/conf/httpd.conf
Any other ideas?
-G.
Then use the same way as how Apache configure it
