Hi, I installed the CyberPanel In my AWS EC2 with the oficial AMI of MarketPlace.
When I login in PHPMyAdmin I have this error:
$cfg[‘TempDir’] (/usr/local/CyberCP/public/phpmyadmin/tmp) is not accessible.
I had this issue and it was mind numbing to figure out. I hope this saves folks trouble as it cost me hours. I don’t know if it will work on AWS EC2 but below is what fixed it for me.
Here is how I fixed it for me… edit the config file /usr/local/CyberCP/public/phpmyadmin/config.inc.php
I had to change:
$cfg[‘TempDir’] = ‘tmp’;
to
$cfg[‘TempDir’] = ‘/tmp/’;
And that fixed the error for me on Ubuntu 20.04.2 LTS
running CyberPanel:
Current Version
2.1
Build
1
Latest Version
2.1
Latest Build
1
Sometimes because of permission happens
sudo chown 777 -R /tmp
*** please add it under the /usr/local/CyberCP/public/phpmyadmin/ in the config.inc.php file that line
$cfg[‘TempDir’] = ‘/usr/local/CyberCP/public/phpmyadmin/tmp’;
some additional info
149
The normal settings for /tmp
are 1777, which ls
shows as drwxrwxrwt
. That is: wide open, except that only the owner of a file can remove it (that’s what this extra t
bit means for a directory).
The problem with a /tmp
with mode 777 is that another user could remove a file that you’ve created and substitute the content of their choice.
If your /tmp
is a tmpfs filesystem, a reboot will restore everything. Otherwise, run chmod 1777 /tmp
Additionally, a lot of files in /tmp
need to be private. However, at least one directory critically needs to be world-readable: /tmp/.X11-unix
, and possibly some other similar directories (/tmp/.XIM-unix
, etc.). The following command should mostly set things right:
chmod 1777 /tmp
find /tmp -mindepth 1 -name '.*-unix' -exec chmod 1777 {} + -prune -o -exec chmod go-rwx {} +
I.e. make all files and directories private (remove all permissions for group and other), but make the X11 sockets accessible to all. Access control on these sockets is enforced by the server, not by the file permissions. There may be other sockets that need to be publicly available. Run find /tmp -type s -user 0
to discover root-owned sockets which you may need to make world-accessible. There may be sockets owned by other system users as well (e.g. to communicate with a system bus); explore with find /tmp -type s ! -user $UID
(where $UID
is your user ID).
