I seeFailed to start firewalld.service: Unit is masked`
try run
systemctl unmask firewalld
and <code class="CodeInline">systemctl enable firewalld
before installation
I’ll test here, thx
problem solved from the firewalld part !
try run
before installation
I’ll test here, thx
then I will post the error that in the middle of the remote backup
Please use a separate thread for that.
then I will post the error that in the middle of the remote backupPlease use a separate thread for that.
right, you think that after installing the cyberpanel it is not recommended to use the: “yum update -y”
It is fine, you can run the update.
