Check video: Recording #5
Desction: When add domain alias (use for WP Multisite), SSL domain aliass conflic. If use feature"issue SSL" in domain alias, so a domain a SSL, all other domain get error
Can you show me how to fix add domain alias for WP multisite with SSL?
This issue very important with me. I can’t make core site when domain aliass haven’t SSL.
This isue is my last issue, when dev Core Web
Thanks for your help
ThaiT
Instead of aliasing each domains for multisite , create them domains as addon domains with same document root ( piublic_html) this will make each domain will have its own virtualhost entries and will have separate SSL certs
for alias there is some issues when we issue SSL, when we install SSL for alias domain it may replace SSL for main domain, some how the SSL expanding doesn’t happens for alias domains
