Hi, i got problem: i can not received email and send email.
this is my email log when received email:
Dec 17 11:55:54 centos7x64 dovecot: imap-login: Login: user=info@webipro.id, method=PLAIN, rip=::1, lip=::1, mpid=79580, TLS, session=<P+qeAuWZqJwAAAAAAAAAAAAAAAAAAAAB>
Dec 17 11:55:54 centos7x64 dovecot: imap(info@webipro.id)<79580><P+qeAuWZqJwAAAAAAAAAAAAAAAAAAAAB>: Logged out in=96 out=1010 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Dec 17 11:56:00 centos7x64 postfix/smtpd[79586]: connect from mail-lj1-f170.google.com[209.85.208.170]
Dec 17 11:56:02 centos7x64 postfix/smtpd[79586]: 5C1789C8C7: client=mail-lj1-f170.google.com[209.85.208.170]
Dec 17 11:56:02 centos7x64 postfix/cleanup[79594]: 5C1789C8C7: message-id=CAEt3qN=mDRekoikO=6qYy0_SG4nJOMGdR2aM9-usjHn7TLj66Q@mail.gmail.com
Dec 17 11:56:02 centos7x64 opendkim[61506]: 5C1789C8C7: mail-lj1-f170.google.com [209.85.208.170] not internal
Dec 17 11:56:02 centos7x64 opendkim[61506]: 5C1789C8C7: not authenticated
Dec 17 11:56:02 centos7x64 opendkim[61506]: 5C1789C8C7: DKIM verification successful
Dec 17 11:56:02 centos7x64 postfix/qmgr[79388]: 5C1789C8C7: from=erwindevsmtp@gmail.com, size=2520, nrcpt=1 (queue active)
Dec 17 11:56:02 centos7x64 postfix/pipe[79596]: fatal: get_service_attr: unknown username: spamd
Dec 17 11:56:03 centos7x64 postfix/smtpd[79586]: disconnect from mail-lj1-f170.google.com[209.85.208.170] ehlo=2 starttls=1 mail=1 rcpt=1 bdat=1 quit=1 commands=7
Dec 17 11:56:03 centos7x64 postfix/qmgr[79388]: warning: private/spamassassin socket: malformed response
Dec 17 11:56:03 centos7x64 postfix/qmgr[79388]: warning: transport spamassassin failure – see a previous warning/fatal/panic logfile record for the problem description
Dec 17 11:56:03 centos7x64 postfix/master[79386]: warning: process /usr/libexec/postfix/pipe pid 79596 exit status 1
Dec 17 11:56:03 centos7x64 postfix/master[79386]: warning: /usr/libexec/postfix/pipe: bad command startup – throttling
Dec 17 11:56:03 centos7x64 postfix/error[79602]: 5C1789C8C7: to=info@webipro.id, relay=none, delay=1.1, delays=0.09/1/0/0, dsn=4.3.0, status=deferred (unknown mail transport error)
this is my log when send email:
Dec 17 11:58:53 centos7x64 dovecot: imap-login: Login: user=info@webipro.id, method=PLAIN, rip=::1, lip=::1, mpid=79690, TLS, session=
Dec 17 11:58:53 centos7x64 dovecot: imap(info@webipro.id)<79690>: Logged out in=96 out=1010 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Dec 17 11:59:01 centos7x64 postfix/smtp[79661]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:400e:c00::1a]:25: Connection timed out
Dec 17 11:59:01 centos7x64 postfix/smtp[79664]: connect to alt1.gmail-smtp-in.l.google.com[173.194.202.26]:25: Connection timed out
Dec 17 11:59:01 centos7x64 postfix/smtp[79667]: connect to alt1.gmail-smtp-in.l.google.com[173.194.202.26]:25: Connection timed out
Dec 17 11:59:01 centos7x64 postfix/smtp[79668]: connect to mta5.am0.yahoodns.net[67.195.228.106]:25: Connection timed out
Dec 17 11:59:01 centos7x64 postfix/smtp[79669]: connect to alt1.gmail-smtp-in.l.google.com[173.194.202.26]:25: Connection timed out
Dec 17 11:59:01 centos7x64 postfix/smtp[79672]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:400e:c00::1a]:25: Connection timed out
Dec 17 11:59:01 centos7x64 dovecot: imap-login: Login: user=info@webipro.id, method=PLAIN, rip=::1, lip=::1, mpid=79692, TLS, session=
Dec 17 11:59:01 centos7x64 postfix/submission/smtpd[79693]: connect from localhost[::1]
Dec 17 11:59:02 centos7x64 postfix/submission/smtpd[79693]: 169D69C8C6: client=localhost[::1], sasl_method=PLAIN, sasl_username=info@webipro.id
Dec 17 11:59:02 centos7x64 postfix/cleanup[79696]: 169D69C8C6: message-id=c12d2df774dc8f958e34c7f7c8d7bd74@webipro.id
Dec 17 11:59:02 centos7x64 opendkim[61506]: 169D69C8C6: DKIM-Signature field added (s=default, d=webipro.id)
Dec 17 11:59:02 centos7x64 postfix/qmgr[79388]: 169D69C8C6: from=info@webipro.id, size=1154, nrcpt=1 (queue active)
Dec 17 11:59:02 centos7x64 postfix/submission/smtpd[79693]: disconnect from localhost[::1] ehlo=2 starttls=1 auth=1 mail=1 rcpt=1 data=1 quit=1 commands=8
Dec 17 11:59:02 centos7x64 dovecot: imap(info@webipro.id)<79692>: Logged out in=1063 out=1434 deleted=1 expunged=1 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Dec 17 11:59:02 centos7x64 dovecot: imap-login: Login: user=info@webipro.id, method=PLAIN, rip=::1, lip=::1, mpid=79700, TLS, session=
Dec 17 11:59:02 centos7x64 dovecot: imap(info@webipro.id)<79700>: Logged out in=96 out=1011 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
Dec 17 11:59:31 centos7x64 postfix/smtp[79661]: connect to alt1.gmail-smtp-in.l.google.com[173.194.202.27]:25: Connection timed out
Dec 17 11:59:31 centos7x64 postfix/smtp[79664]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:400e:c00::1a]:25: Connection timed out
Dec 17 11:59:31 centos7x64 postfix/smtp[79667]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:400e:c00::1a]:25: Connection timed out
Dec 17 11:59:31 centos7x64 postfix/smtp[79668]: connect to mta6.am0.yahoodns.net[67.195.204.73]:25: Connection timed out
Dec 17 11:59:31 centos7x64 postfix/smtp[79669]: connect to alt1.gmail-smtp-in.l.google.com[2607:f8b0:400e:c00::1a]:25: Connection timed out
Dec 17 11:59:31 centos7x64 postfix/smtp[79672]: connect to alt1.gmail-smtp-in.l.google.com[173.194.202.27]:25: Connection timed out
Dec 17 12:00:01 centos7x64 postfix/smtp[79661]: connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1b]:25: Connection timed out
Dec 17 12:00:01 centos7x64 postfix/smtp[79664]: connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1b]:25: Connection timed out
Dec 17 12:00:01 centos7x64 postfix/smtp[79667]: connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1a]:25: Connection timed out
Dec 17 12:00:01 centos7x64 postfix/smtp[79668]: connect to mta6.am0.yahoodns.net[98.136.96.76]:25: Connection timed out
Dec 17 12:00:01 centos7x64 postfix/smtp[79669]: connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1a]:25: Connection timed out
Dec 17 12:00:01 centos7x64 postfix/smtp[79672]: connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1b]:25: Connection timed out
Dec 17 12:00:01 centos7x64 postfix/smtp[79661]: B16729C8B6: to=erwindevsmtp@gmail.com, relay=none, delay=3540, delays=3390/0.02/150/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1b]:25: Connection timed out)
Dec 17 12:00:01 centos7x64 postfix/smtp[79664]: 502349C8B3: to=erwindevsmtp@gmail.com, relay=none, delay=3741, delays=3591/0.04/150/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1b]:25: Connection timed out)
Dec 17 12:00:01 centos7x64 postfix/smtp[79667]: 06A4B9C89C: to=erwin.t4n@gmail.com, relay=none, delay=97034, delays=96884/0.06/150/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1a]:25: Connection timed out)
Dec 17 12:00:01 centos7x64 postfix/smtp[79668]: 069F29C8A7: to=erwinatma@yahoo.com, relay=none, delay=24066, delays=23916/0.06/150/0, dsn=4.4.1, status=deferred (connect to mta6.am0.yahoodns.net[98.136.96.76]:25: Connection timed out)
Dec 17 12:00:01 centos7x64 postfix/smtp[79669]: 9EA329C8C3: to=erwin.t4n@gmail.com, relay=none, delay=639, delays=489/0.07/150/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1a]:25: Connection timed out)
Dec 17 12:00:01 centos7x64 postfix/smtp[79672]: 872669C8C5: to=erwin.t4n@gmail.com, relay=none, delay=553, delays=403/0.09/150/0, dsn=4.4.1, status=deferred (connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1b]:25: Connection timed out)
Dec 17 12:00:01 centos7x64 postfix/error[79806]: 169D69C8C6: to=erwindevsmtp@gmail.com, relay=none, delay=60, delays=0.09/60/0/0.03, dsn=4.4.1, status=deferred (delivery temporarily suspended: connect to alt2.gmail-smtp-in.l.google.com[2607:f8b0:4003:c14::1a]:25: Connection timed out)
Dec 17 12:00:02 centos7x64 postfix/pickup[79387]: 3FE129C8CA: uid=0 from=
Dec 17 12:00:02 centos7x64 postfix/cleanup[79696]: 3FE129C8CA: message-id=20191217120002.3FE129C8CA@webipro.id
Dec 17 12:00:02 centos7x64 opendkim[61506]: 3FE129C8CA: DKIM-Signature field added (s=default, d=webipro.id)
Dec 17 12:00:02 centos7x64 postfix/qmgr[79388]: 3FE129C8CA: from=root@webipro.id, size=851, nrcpt=1 (queue active)
Dec 17 12:00:02 centos7x64 postfix/pipe[79826]: 3FE129C8CA: to=root@webipro.id, orig_to=, relay=dovecot, delay=0.1, delays=0.08/0.01/0/0.02, dsn=5.1.1, status=bounced (user unknown. Command output: lda(root@webipro.id): Error: net_connect_unix(/var/run/dovecot/stats-writer) failed: Permission denied )
Dec 17 12:00:02 centos7x64 postfix/cleanup[79696]: 52D8C9C8CB: message-id=20191217120002.52D8C9C8CB@webipro.id
Dec 17 12:00:02 centos7x64 postfix/qmgr[79388]: 52D8C9C8CB: from=<>, size=3186, nrcpt=1 (queue active)
Dec 17 12:00:02 centos7x64 postfix/bounce[79828]: 3FE129C8CA: sender non-delivery notification: 52D8C9C8CB
Dec 17 12:00:02 centos7x64 postfix/qmgr[79388]: 3FE129C8CA: removed
Dec 17 12:00:02 centos7x64 postfix/pipe[79826]: 52D8C9C8CB: to=root@webipro.id, relay=dovecot, delay=0.02, delays=0/0/0/0.01, dsn=5.1.1, status=bounced (user unknown. Command output: lda(root@webipro.id): Error: net_connect_unix(/var/run/dovecot/stats-writer) failed: Permission denied )
Dec 17 12:00:02 centos7x64 postfix/qmgr[79388]: 52D8C9C8CB: removed
Dec 17 12:00:53 centos7x64 dovecot: imap-login: Login: user=info@webipro.id, method=PLAIN, rip=::1, lip=::1, mpid=79836, TLS, session=
Dec 17 12:00:53 centos7x64 dovecot: imap(info@webipro.id)<79836>: Logged out in=89 out=1003 deleted=0 expunged=0 trashed=0 hdr_count=0 hdr_bytes=0 body_count=0 body_bytes=0
do you know guys what’s the problem?
thank you
