I’m getting this error when I try to issue SSL to my subdomain: 0,283 Failed to obtain SSL for domain. [issueSSLForDomain]. I’m using cloudflare but is only DNS mode (grey cloud).
@kaz050457 said:
https://support.cloudflare.com/hc/en-us/articles/200170416-What-do-the-SSL-options-mean-
I don’t have any problem with cloudflare. But thanks for trying to help
Do take a look at ISSUE SSL FOR HOSTNAME not working — CyberPanel - WebHosting Control Panel for OpenLiteSpeed
First, find out what is wrong.
@CyberPanel said:
Do take a look at ISSUE SSL FOR HOSTNAME not working — CyberPanel - WebHosting Control Panel for OpenLiteSpeedFirst, find out what is wrong.
Here are the logs (The subdomain is called re):
[08-45-16-Sun-Feb-2019] float division by zero [getDiskUsage]
[08-45-26-Sun-Feb-2019] Trying to obtain SSL for: re and: www.re
[08-45-28-Sun-Feb-2019] Failed to obtain SSL for: re and: www.re
[08-45-28-Sun-Feb-2019] Trying to obtain SSL for: re
[08-45-30-Sun-Feb-2019] Failed to obtain SSL, issuing self-signed SSL for: re
> @CyberPanel said:
> Do take a look at https://forums.cyberpanel.net/discussion/comment/3524/#Comment_3524
What about logs from CLI?
