[BUG REPORT + FIX] Remote SFTP/Restore
I tried to create an automatic remote backup, but I had connection problems and I realized 2 problems that did not allow it to work correctly.
  1. You need to disable CSF.
  2. You need to make a server-to-server ssh connection so that the fingerprint can be created between the two machines.
Once this is done, the system passes the checks and the CSF can be safely re-enabled.
whitle list the ip in your csf and you don’t need to disable
