@qtwrk said:
yes , the epel.repo is causing issue on BWG as its centos7 comes with it , as a defect one , so had to remove it first and then install new one from centos repo.
it’s not about pip , it’s just epel not working correctly on BWG
I’ve tried vesta for several times, and I am sure it’s not a badly-designed panel. However bwh seems to be not co-operative with some panels. Thinking about abandoning it or switching to some other reliable vps providers.
I also installed debian, but the official os provided by bwh seems not a clean one. It has exim or sth with it, so vesta prompts that it is not a clean one and requires an uninstall before going on.
I guess bwh team knows all these problems. Why don’t they improve? These distros are free.
After April 9 when cp releases its new ver, your cn scripts will still include the remedy lines and the official one keeps as it has been?
official script is now fixed , yes , I will keep update it.
Another info for you. Remembered previously you asked about phpmyadmin upload via net? I told you it could be bt.cn panel, or aaPanel’s integrated phpmyadmin. I tried again, and it’s not.
it requires set a /path to where SQL stored , but if you use cyberpanel as shared hosting server that for multiple users , I don’t know how to set this.
it’s OK for one-man managed VPS , but when it comes to multiple users , couldn’t find a way to isolated them from my knowledge…
