This panel is awesome, but need some improvement badly.
Auto ssl install and renewal based on cron
Softacolous integration or more one click installer scripts
Cloudflare integration
One click API Enabled for all user ( its a must have feature because if you do not enable api your whmcs user will not be able to manage/change or login using api. and if you have 100 user it’s really difficult to enable api for all user one by one )
Current add domain is little bit confusing for beginners. To remove confusion you can add two icon one writing subdomain another writing addon domain.
one click to login as user, some time we need to login in your account to check, i know i can manage it from admin account but it will best if there is auto login system.
email pipe to php script ( required for whmcs ticket )
one click to login phpmyadmin and email autologin
Set created ACL as default for new account currently user acl select as default when we create account from whmcs, but we want to use other acl which has backup restore enabled.
All these features will definitely make this panel one of the best hosting panel.
