Hello
I try to set as destination, remotely, my own Synology backup as I used in the past with Plesk.
Unfortunately I cannot creste in Synology the user root which is reserved.
Cyberpanel automatically assumes that the user is root so when it tries to connect it throw an error.
Is it possible at the next update to have the possibility to manually fill in the remote destination user and so on?
Thank you
