hi how to restore backup website in user account
https://fastpic.co/image/iSjQJM
https://fastpic.co/image/iSj2Ph
You need to move the backup file to /home/backup directory in order to restore it.
but file is already in home/backup directory
This page can be used to restore your websites, Back up should be generated from CyberPanel Back up generation tool, it will detect all Back ups under /home/backup
i am confusing /home/backup directory
cyber panel generate backup /home/domain name/backup
but how to put file home/backup directory because it does not allow to me and user account to move back to home/ directory
ssh into the server as root and run this command
cp /home/yourdomain.com/backup/your-backupfile-name.tar.gz /home/backup
thanks for help now file back up and restore is working
Ola estou com dificuldade de fazer upload do backup do meu antigo site para o syberpanel… alguem poderia me orientar? pois escolho restaurar na hora que e pra selecionar o arquivo nao aparece nada nenhum arquivo.
https://uploaddeimagens.com.br/imagens/sem_titulo-jpg-fa3ab0ac-1bf0-474c-8378-320b8a24a14a
Ola estou com dificuldade de fazer upload do backup do meu antigo site para o syberpanel.. alguem poderia me orientar? pois escolho restaurar na hora que e pra selecionar o arquivo nao aparece nada nenhum arquivo.
Olá amigo, estou com este mesmo problema, por acaso você conseguiu resolver? Se sim, poderia passar a solução?
