When I use the Cyberpanel backup feature and take a backup of the website, I see that the database size is 17.7 mb.
However, when I exported the database from phpmyadmin, I saw that the size was 18mb. Is there a problem with the backup feature? Does it back up all data of the website?
Size seems almost same and there is no such issue with back and all data will be ok
i think that because cluster size
I want to make sure there is no data loss in the backup. This is important. Thanks for the replies.
the only way to know it is make another backup if still same size then if you still worried, you need to extract it
