if not update cp, and only
dnf check-update
dnf update
and reboot
all work fine
wtf?
dnf check-update
dnf update
and reboot
all work fine
wtf?
Dear normal cyberpanel update will be preferred instead of doing the dnf update.
may be some package get updated that is not needed but it is not the thing that it is impossible to use dnf update you can use it but prefer to update cyberpanel.
i only update os, trough dnf update
if i update panel - server crashed
can you send the email to [email protected] so I can check
with last commit (bfc2fc4c9521427dc3b58a5bd38f53814cc0d22a) updates install fine, server working
CP developers didn’t see the problem, I wrote about it long before they started breaking the servers.
