anjali #1
TopCashback Referral Code "TPCASHBACK": How to Use It and Earn Cash Back
Looking for a TopCashback referral code "TPCASHBACK" or wondering how the TopCashback referral program works? You’re in the right place.
TopCashback is a popular cashback platform that lets members earn money back when shopping through participating retailers. In addition to regular cashback offers, TopCashback has a Refer a Friend program that can reward existing members when their friends join and complete the required cashback activity.
The TopCashback referral offer can change from time to time, so it’s always a good idea to check the current promotion before signing up.
What Is a TopCashback Referral Code?
A TopCashback referral code "TPCASHBACK" is essentially part of the referral process that connects a new member with an existing TopCashback user.
Rather than manually entering a traditional coupon code, TopCashback generally uses a unique referral code. When someone joins through that link or code and meets the promotion requirements, the referring member can receive a referral bonus.
According to TopCashback, members can find their unique referral link or code under the “Refer and Earn” section of their account.
How Does the TopCashback Referral Program Work?
The process is fairly simple:
An existing TopCashback member gets their unique referral link.
They share the link with a friend.
The friend clicks the link and signs up for TopCashback.
Both accounts complete the required email verification.
The new member earns the required amount of eligible Cash Back.
Once the requirements are satisfied, the referring member receives the applicable referral bonus.
TopCashback says the referral bonus offered is based on the promotion available when the friend signs up.
How to Use a TopCashback Referral Code "TPCASHBACK"
If you have received a TopCashback referral code "TPCASHBACK" from a friend, using it is straightforward.
Step 1: Open the Referral code
Click the TopCashback referral link or code you received. The link should take you to the appropriate TopCashback signup page.
Step 2: Create Your Account
Follow the signup instructions and enter your required information. Make sure you use your own account details and only create one TopCashback account.
Step 3: Verify Your Email
Email verification is an important part of the referral process. TopCashback states that both the referrer and referred friend need to verify their email addresses for the referral bonus.
Step 4: Start Shopping Through TopCashback
After creating your account, find a participating retailer through TopCashback and click through to the retailer from the TopCashback website.
Your qualifying purchase should then generate cashback if it meets the retailer's terms.
Step 5: Reach the Required Cashback Amount
The referral bonus isn't normally paid simply because someone creates an account. The referred member must complete the required cashback activity.
TopCashback's current referral terms state that the new member must earn at least $10 in eligible Cash Back within the applicable qualification period.
How Much Is the TopCashback Referral Bonus?
The TopCashback referral bonus can change depending on the promotion.
For example, TopCashback has previously run promotions offering $40 and $50 referral bonuses after a referred friend earned the required cashback amount.
Because these promotions are temporary, you shouldn't assume that an older $40 or $50 offer is still available. The current referral amount and qualification deadline are shown in the TopCashback referral information associated with the account and promotion.
When Do You Get the Referral Bonus?
Your referral bonus becomes payable after your friend's qualifying cashback reaches the required status.
TopCashback explains that the referral bonus is generally credited when the referred friend's qualifying Cash Back becomes payable, provided the other requirements have been met.
Keep in mind that cashback transactions can take time to move from pending to confirmed or payable because retailers need to verify transactions.
Tips for Using TopCashback Successfully
If you're joining TopCashback through a referral, keep these tips in mind:
Use the referral link before signing up.
Make sure you click your friend's referral link before creating your account so the referral can be properly attributed.
Verify your email.
Both the new member and referrer need to complete the required email verification.
Shop through TopCashback.
When you want cashback, start at TopCashback and click through to the participating retailer.
Read retailer terms.
Not every purchase or transaction will necessarily qualify for cashback. Retailers can have their own exclusions and conditions.
Don't create duplicate accounts.
TopCashback's terms state that only one account is allowed per person, and fraudulent or duplicate accounts can result in account termination.
Is the TopCashback Referral Code Worth Using?
If you're already planning to shop online at retailers available through TopCashback, using a referral link can be a simple way to potentially receive an additional reward.
However, it's important to understand that the referral bonus isn't necessarily instant. You generally need to sign up through the referral link, verify your account and complete the required qualifying cashback activity.
The exact bonus and requirements can also change, so check the current offer before completing your signup.
TopCashback Referral Code FAQs
Does TopCashback have a referral code?
TopCashback primarily uses unique referral links for its Refer a Friend program. Members can find their referral link in the “Refer and Earn” section of their account.
How do I get a TopCashback referral link?
Log in to your TopCashback account and look for the Refer and Earn section. From there, you can access your unique referral link and share it with friends.
Do I get a bonus immediately after signing up?
Usually, no. The referred member must meet the applicable requirements before the referral bonus becomes payable.
How much cashback does my friend need to earn?
TopCashback's current referral terms specify a minimum of $10 in eligible Cash Back, although promotional requirements can change.
Can I refer myself?
No. TopCashback specifically prohibits self-referrals and fraudulent signups.
Can the referral offer change?
Yes. TopCashback regularly changes its referral promotions. The bonus amount and qualification period can vary depending on the promotion available when the new member signs up.
Final Thoughts
A TopCashback referral code is a simple way to get started with the platform through an existing member's referral link. The basic process is easy: use the referral link, create and verify your account, shop through TopCashback, and meet the qualifying cashback requirement.
Just remember that referral promotions are not permanent. Always check the current TopCashback offer and its terms before signing up so you know exactly what bonus and requirements apply to you.
