Neuhaus Barsuhn #1
When I use an AI coding assistant for server or web maintenance, the biggest planning mistake is treating a reset estimate as a promise. A small measurement log makes the work much easier to schedule.
My workflow is:
  1. Record the current usage level and the exact observation time.
  2. Separate direct reset observations from any banked or carried-over usage.
  3. Keep deployment, backup, and rollback work in independent milestones.
  4. Check the state again before starting a long migration or configuration change.
  5. Review the history afterward and adjust the next session estimate.
For anyone who wants a simple reference while following this workflow, Codex Reset Radar provides current limit checks, reset status, reset history, and public reset announcements. I treat it as a planning input rather than a guarantee, and I still keep normal server backups and rollback steps in place.
This approach has been especially useful for breaking a long infrastructure task into checkpoints that can safely stop between usage windows.
