videoeditortrick #1
[GUIDE] Proxy Seller Coupon Code — Quick Reference
Making this short because most threads on this overcomplicate it.
Code: CBFHWA_724137
Enter it at checkout, in the promo/coupon field. Total should drop before you pay.
Where the field actually is
Not on the product page. It's on the checkout / order summary screen, sometimes hidden behind a "Have a coupon?" link you have to click. If you're looking on the plan selection page and don't see a discount box, that's why.
Enter it correctly
Copy-paste it. Don't type it from memory. It's an underscore between the letters and numbers, not a hyphen — that's the #1 way people mess this up. Also check you didn't grab a trailing space when copying.
If you're on mobile, watch autocorrect. It'll happily capitalize or "fix" the code without telling you.
Actually verify it worked
This is the part people skip. Look at the order total after you click apply. The field accepting your input with no error is NOT confirmation. Plenty of checkouts fail silently — no error, total just stays the same, and you don't notice unless you're specifically looking.
If it doesn't apply
In order:
  1. Clear the field, re-paste clean
  2. Refresh the page, rebuild the cart
  3. Try incognito (ad blockers/privacy extensions can break the validation script — this is real, happened to me)
  4. Try a different plan or billing term, some promos are restricted
  5. Message support and ask what's currently active
Does it work on renewals?
Worth asking support directly rather than assuming. Terms vary and can change. Just check the total at every checkout, same as you would on a new order.
Is it permanent?
No code is. Merchants change or pull promos whenever they want, no notice required. Verify at checkout each time rather than assuming it'll always work.
One thing worth saying: the code is the small part of this. Picking the right proxy type for your actual targets matters way more. Datacenter is cheap but easy to detect, residential works on sites that block datacenter ranges, mobile is for the strict platforms (multi-account social stuff). A discount on the wrong type is still the wrong type.
Also don't overbuy quantity. Start small, run it a cycle, look at actual usage, then scale. Everyone overestimates the first time.
That's it. Takes 30 seconds to apply, no reason not to.
