Ranjeet Kumar #1
Data experts always deal with huge numbers and large volumes of data daily. Simple spreadsheets turn into an absolute mess without using the right tools. Many of the people end up wasting their valuable time on copy-paste and manual sorting tasks. It is very easy to get a command over complicated tasks with the help of Advanced Excel Online Training.
This training will help in reducing a lot of boring and tiresome work in daily routine by using advanced features. These features convert those complex numbers into elegant reports that would be submitted to your bosses. You will easily crack the toughest job interviews with the help of these features.
1. XLOOKUP and Dynamic Arrays for Smarter Analysis
The old lookup functions always fail if there is any change in the order of columns. The new XLOOKUP function solves this major problem easily and perfectly. It searches data from the left side or the right side without failing.
• Exact match: It gives an exact match by default without writing anything extra.
• No breaking: It never fails if you add new columns.
• More flexible: It can look up horizontal and vertical data without any difficulty.
Let's take the example of practical life where you are analysing daily sales of the shop. You use the XLOOKUP function to get the price of products using the product code instantly. New dynamic array formulas such as FILTER and UNIQUE give results in multiple cells automatically. Students interested in learning can enrol in Advanced Excel Course in Noida.
2. Power Query Simplifies Data Cleaning
It is time-consuming to clean dirty data manually. Power Query makes this process automatic with just a couple of mouse clicks. All data cleaning processes will be saved and will be updated automatically with new data.
• Import easily: connect to large databases or text files.
• Fast cleaning: Delete blank rows and bad errors very fast.
• Auto-update: update data in an instance without any manual process again.
Suppose you have a messy CSV file coming from your boss on Mondays every week. Power Query cleans the messy data in the background while you analyse the data. This amazing tool can be learned through Advanced Excel Training in Gurgaon.
3. Pivot Tables Turn Raw Data into Business Insights
Pivot Tables help you change thousands of rows into small, clean tables. You can group long dates by months or years to see secret patterns.
Normal Tables - Need manual sorting, hard to change, slow formula updates.
Pivot Tables - Automatically group data, drag-and-drop fields, fast refresh.
You can group sales data by city to see where sales are high. This feature helps big companies make very fast business decisions.
4. Other Advanced Excel Features Worth Learning
A good data worker must be proficient in lots of useful advanced functions and formulas. When you learn many features, you become able to deal with any complex data.
• Power Pivot: Connect two or three tables effortlessly.
• Conditional Formatting: Automatically change the colour of a cell to highlight wrong numbers.
• Data Validation: Prevent wrong typing before making mistakes.
• Easy Slicers: Apply filters to your Pivot Tables with helpful large buttons.
These features help you create impressive dashboards for your office manager. They allow you to turn a simple Excel table into an advanced database.
Learning these advanced spreadsheet skills is the only way you can go from being an average user to a data professional. Automate your data processing, use smart lookups, and create interactive pivot tables. You save time and provide useful insights for your company. Practice every day with useful datasets to gain the skills needed to become a successful data analyst.
