BlazeFlare19 #1
In ARC Raiders, the Canister is an essential material with multiple uses, especially for crafting and recycling. As an experienced player, you’ll need to understand its various applications to make the most of this item in your gameplay. This guide explains how to use the Canister effectively, the best ways to obtain it, and how it fits into crafting recipes.
What is the Canister?
The Canister is an Uncommon item in ARC Raiders, which can be found in several locations and used in crafting a variety of items. It is a versatile material that is often used in advanced crafting recipes, and it’s also an essential component in recycling. Players will encounter this item as they progress through the game, particularly in activities like scavenging, recycling, and crafting.
Key Information about the Canister:
  • Rarity: Uncommon
  • Weight: 0.25
  • Stack Size: 15
  • Sell Price: 300 coins
  • Recycling Output: 3 Plastic Parts per Canister
Where to Find Canisters?
Canisters can be sourced through a few primary methods, and knowing where to look can save you time:
  1. Scavenging: As you explore the game world, you will find Canisters scattered in various locations. These are often in containers or as loot dropped by enemies.
  2. Recycling: You can recycle other items to obtain Canisters. This is a useful method when you have spare materials that you no longer need.
  3. Purchase from NPCs: The Canister can also be bought from NPC vendors like Celeste in the game for 300 coins.
How to Craft with Canisters?
Canisters are required in several high-level crafting recipes. Here’s a look at how they are used in creating various items:
Example Recipes:
  1. Bettina I (Gunsmith 3)
  • Ingredients: 3 Advanced Mechanical Components, 3 Heavy Gun Parts, 3 Canisters
  • This recipe unlocks the creation of Bettina I, a useful weapon blueprint for your arsenal.
  1. Heavy Fuze Grenade (Explosives Station 3)
  • Ingredients: 1 Explosive Compound, 2 Canisters
  • The Heavy Fuze Grenade is an explosive item that can be used in combat for dealing damage.
  1. Smoke Grenade (Workbench, Utility Station 1)
  • Ingredients: 14 Chemicals, 1 Canister
  • The Smoke Grenade is a tactical item that helps to obscure vision in battles.
  1. Vita Spray (Medical Lab 3)
  • Ingredients: 3 Antiseptic, 1 Canister
  • The Vita Spray is a healing item that restores health to you or your teammates.
Recycling Canisters
One of the most useful properties of the Canister is its recyclability. When recycled, it provides Plastic Parts, a valuable crafting material. You can recycle a Canister for 3 Plastic Parts, which can then be used in other crafting recipes, reducing your need for new resources.
Additionally, Canisters are often salvaged from items like Bicycle Pumps, Flame Sprays, and other equipment, making them easy to come by when you’re focusing on recycling your unused materials.
Common Use Cases for Canisters
Here are some practical ways to use Canisters in your daily gameplay:
  1. Crafting Essential Items: Whether you’re looking to craft explosives, grenades, or healing items, Canisters are often a key ingredient. Prioritize Canisters in your resource collection if you plan on crafting these items frequently.
  2. Recycling for Plastic Parts: Given their low weight and stackable nature, Canisters are a great item to recycle when you’re in need of plastic parts for other crafts.
  3. Selling for Profit: If you have an excess of Canisters and don’t need them immediately, selling them for 300 coins each can be a smart way to generate income. You can use the funds to buy more critical resources.
Should You Buy Canisters?
If you’re ever in need of a quick batch of Canisters, you can always opt to buy arc raiders blueprints or Canisters directly from vendors or the marketplace. However, crafting and scavenging are often more efficient and cost-effective in the long run.
Canisters may not be the flashiest item in ARC Raiders, but their versatility and importance in crafting and recycling make them a valuable resource to manage. Whether you’re crafting key items, recycling for plastic parts, or selling them for coins, understanding how to best utilize Canisters will help you stay ahead in your quest to dominate ARC Raiders. Keep them in mind as you plan your resource strategy!
