I have an issue with Generated SSL for the Hostname
CT
Clicks Tech #1
Dear Team, Please help to fix the ssl issue for the Hostname name also i am using cloudflare and based on what i know that i must to make the A Record DNS Only not proxied. When i am entering to check the status find that the SSL active but the Panel link still running on unprotected mode and i dont know what to fix this issue. Please check attached photos.
I can not upload photos on the time been for a new user issue.
RM
Rana Muhammad Usman Nasir #2
SSL Hostname Issue - Log Collection Guide
To properly diagnose your SSL hostname issue, please collect the following logs and share them. This will help us identify the exact problem.
Step 1: CyberPanel Main Error Log
sudo tail -n 100 /home/cyberpanel/error-logs.txt
Step 2: Recent SSL-Related Logs
Filter for SSL-related entries from the last 24 hours
 sudo grep -i "ssl\|certificate\|hostname" /home/cyberpanel/error-logs.txt | tail -n 50
Step 3: Check Let’s Encrypt Certificate Status
Replace ‘your-hostname.com’ with your actual hostname
  sudo ls -la /etc/letsencrypt/live/your-hostname.com/
  sudo openssl x509 -in /etc/letsencrypt/live/your-hostname.com/fullchain.pem -text -noout | grep -A 2 "Subject:"
Step 4: Check Certificate Symlinks
Check if admin panel certificates are properly linked
  sudo ls -la /usr/local/lscp/conf/cert.pem
  sudo ls -la /usr/local/lscp/conf/key.pem
  sudo ls -la /usr/local/lsws/admin/conf/cert/admin.crt
  sudo ls -la /usr/local/lsws/admin/conf/cert/admin.key
Step 5: DNS Validation Check
  dig @8.8.8.8 your-hostname.com A
  dig @8.8.8.8 your-hostname.com AAAA
Step 6: SSL Configuration Status
Check if SSL is properly configured in LiteSpeed
  sudo grep -A 5 -B 5 "your-hostname.com" /usr/local/lsws/conf/httpd_config.conf
Step 7: Recent SSL Attempt Logs
If you recently tried to issue SSL, check for recent attempts
  sudo grep -i "issueSSLForDomain\|issueSSLForHostName" /home/cyberpanel/error-logs.txt | tail -n 20
:locked: What to Share Safely:
:white_check_mark: Safe to share:
  • Error messages and timestamps
  • SSL certificate subject/issuer information
  • DNS resolution results
  • Configuration status (without sensitive paths)
:cross_mark: Do NOT share:
  • Private keys or certificate content
  • Full file paths containing usernames
  • Email addresses or sensitive server information
:memo: Additional Information Needed:
  1. Your exact hostname (e.g., panel.yourdomain.com)
  2. When did you first notice the issue?
  3. Did SSL work before, or is this a new installation?
  4. Are you using Cloudflare or other CDN?
  5. What’s the exact error message you see in the browser?
:bullseye: What We’re Looking For:
  • DNS resolution failures
  • Certificate generation errors
  • Symlink creation problems
  • LiteSpeed configuration conflicts
