Nobody helps me with this problem
Ca
Carlos #1
Nobody helps me with this problem, it won’t let me send email, I get this error
Screenshot_5
Help Help
LT
Luveedu Team #2
Hello
Login with SSH and check
telnet yourmainserver.com 25
and check Mail Server SSL
using: //email/testTo:
And then check the
systemctl status postfix
systemctl status dovecot
Check Snappy Mail Admin
I can't send mail - #6 by josephgodwinke.
Also try login with IMAP or POP3 to Outlook or any other mail clients. Use the proper credentials and try sending email from these external clients.
Ca
Carlos #3
Nothing works for me at all
LT
Luveedu Team #4
If you have tried this, you should post the results screenshot then someone can understand and help you. Otherwise who will be interested.
