Why does CyberPanel process keep restarting?
P
P #1
I ran the following 2 commands:
systemctl stop lscpd
systemctl disable lscpd
This stops the CyberPanel process but every 3-4 days the process restarts automatically. Why is this happening? Is there some other command I have to run as well?
Thanks.
Au
Augusto #2
Hi, did you find the solution?
