Ssl sni problem, not trusted mismatch domain
al
abdelghafour lamrani #1
I have one cyber panel account that host multiple website under 1 IP address. But the issue is that when I check example1.com website on SSL labs, it show another domain which prevent show the issue listed above in the screenshot. for more information see the Certificate #2: EC 256 bits (SHA384withECDSA) No SNI. Can someone please help me to fix the issue
LT
Luveedu Team #2
Make sure your domain is pointing to the IP or its hiding. DM me so that I can check it better.
The issue is mainly causing many domains as because of SNI changes. You can try creating simple SSL no wildcard.
Or you can try zerossl 90 days trial or Cloudflare.
al
abdelghafour lamrani #3
Thanks for your message. i have cyberpanel SSL (90days). I have many websites using one IP (server). How to fix the issue?
LT
Luveedu Team #4
The problem is there SANs Mismatch as because of that. SSL doesn’t matter how many IPs you shared. The problem is in CN how many sites mentioned.
FOR EXAMPLE ----
If your SSL is Free HTTP Based ( File Based ) then You need to put 2 different SSL Certificates with 2 different CN or mainly use the general CN. ( Screenshot by Lightshot )
If your SSL is DV Based then You can get multiple CN in one CRT or just wildcard ( Screenshot by Lightshot )
If your SSL is OV/EV based then You are the owner you can do whatever you likes. ( Screenshot by Lightshot )
But in Cyberpanel we have the HTTP based following the File ACME - and that’s why currently you are getting SSL ERROR which you can fix by getting a DV or Email based SSL from these sites I previously mentioned. And then after 3 or 4 days you can again issue cyberpanel SSL.
Also check your SSL CN and SANs from here.
