Closed Cyberpanel Upgrade Failed - Please help
Ma
Malik #1
Hello Everyone
My OS Version is Centos 7.9.2009.
I was trying to upgrade the cyberpanel but unfortunately stuck with it and now unable to access the cyberpanel as it’s giving me “503 Service Unavailable” error on my Cyberpanel hostname page. My current Cyberpanel version was 2.1 and wanted to update it on 2.3.
I used the following command:
cyberpanel_utility
and then going with option 1 for upgrade to stable version.
end response is as follows, pasting the text as i am unable to add the screenshot in the post:
Saving to: ‘/etc/cyberpanel/watchdog.sh’
100%[===================================================================================================================================================>] 5,198 --.-K/s in 0s
2024-11-08 15:06:55 (48.7 MB/s) - ‘/etc/cyberpanel/watchdog.sh’ saved [5198/5198]
Checking LiteSpeed…
WatchDog for LiteSpeed is gone , restarting…
WatchDog for LiteSpeed has been started…
Checking MariaDB…
WatchDog for MariaDB is gone , restarting…
WatchDog for MariaDB has been started…
Checking PowerDNS…
WatchDog for PowerDNS is gone , restarting…
WatchDog for PowerDNS has been started…
Checking Dovecot…
WatchDog for Dovecot is gone , restarting…
WatchDog for Dovecot has been started…
Checking PostFix…
WatchDog for PostFix is gone , restarting…
WatchDog for PostFix has been started…
Checking Pure-FTPd…
WatchDog for Pure-FTPd is gone , restarting…
WatchDog for Pure-FTPd has been started…
chown: cannot access ‘/usr/local/CyberCP/lib64’: No such file or directory
0 1247 0 0 0 0 0 0 --:–:-- 0:00:08 --:–:-- 0
Seems something wrong with upgrade, please check…
[root@konectfood1 ~]#
in above you can see what i get the response at the end. I have tried mulitple times but same result. Kindly help me.
Thank you in advance.
Tc
Tchucho #3
I had the same error on Ubuntu 18. Went at it for 2 days… no luck. Old system could not get it to update. New server, Ubuntu 22, all good. It can be the same think due to CentOS version
RR
Ronny Rolim #4
I have the same problem on Centos 7, has anyone found a solution?
sh
shoaibkk #5
Centos 7 support is no longer active so updates and installation are not possible on this now because many core packages do not support this now.
