My cyberpanel is not working
Wi
Wiseone #1
Hello, my server is not opening 157.173.124.86, port=8090 , all i get is unable to connect, please help
Ka
Kais #2
Read this:
Ka
Kais #3
Wi
Wiseone #4
Hi, thanks but i did not get this email. or how did you get this.
bc
bcat95 #5
SSH connection not working and being rejected
Go to :8090/firewall/secureSSH
click Save Changes then you can login SSH again
Read more here:
Ал
Александр #6
all the files are encrypted :sob: :sob: :sob: :sob: :sob:
sp
splaquet #7
I somehow managed to escape the troubles that others are having (upgrading to v2.3.7), but I’m unable to log in via SSH.
  • after CyberPanel was Upgraded, ssh eventually timed out and logged me out. i haven’t been able to log back in via ssh since… and it simply “times out” on me
  • my password for :8090 isn’t working for me, so i cant update SSH info via panel interface either
any suggestions?
Mi
Mikael99 #8
Reset your admin pass through SSH
If you can’t SSH then login directly to your server through iDRAC or other systems that your hosting company might provide. If not then I don’t know how you will gain ssh access back to the system.
Also 2.3.7 is bad, 2.3.8 is the version that has the fix.
sp
splaquet #9
@Mikael99,
thanks for the reply. …then v2.3.7 would explain why i’m having these problems.
i’m trying to log in via remote IPMI, but have been unsuccessful. i just had a realization that SSH has been stopped… so that’d probably effect my ability to login remotely via ssh, yes/no?
