Backup v2 Error Problem!
He
HeyTurko #1
I provided OneDrive authorization by logging in to Rclone with ssh access via the username. When I want to create a backup with Backupv2, the following error appears. I’ve been dealing with this for hours. What should I do, please help!
La
Laque #3
Im receiving the same error, I created organization and follow all the Rclone documentations, the log return the following:
[05.13.2024_12-26-47] using no config file (./rustic.toml doesn’t exist)
[INFO] rclone output: Failed to create file system for “Cliente escritorio 2:nestdream.com”: couldn’t find root directory ID: Get “https://www.googleapis.com/drive/v3/files/root?alt=json&fields=id&prettyPrint=false&supportsAllDrives=true”: couldn’t fetch token: unauthorized_client: if you’re using your own client id/secret, make sure they’re properly set up following the docs
Following the token created have a old exipry date, maybe this is the problem?
[05.13.2024_12-34-58] cWYSE1+e14R0ra8/UZ+q3a-u nestd rclone config update ‘Rclone’ token '{“access_token”:“ya29.a0AXooCgvlpmA9Ayayz0OqTdryx-jORn4pyERLno4hKJhpfYIkfODiXYu5QJnzb11xRxO7xSSmFtmL2VJcoYG9CUv-0TwI_KvDGWIBs4UN_uaX9-oCwUp9JoClYKXv9EROH614BVvkUbFKd8ji_kr-eAmJLpZEvgWMbMTsaCgYKAWASAMITA0171”,“token_type”:“Bearer”,“refresh_token”:“1//09XZtAKVF-L9Ir0xJRD850kaz_A9t11YSvnADhvee75vsRxXUpZxq7kXxUTCRA_EZQc”*,
“expiry”:“2024-04-08T21:53:00.123456789Z”}'*
–non-interactive
[05.13.2024_12-34-58] {
“State”: “*oauth-confirm,teamdrive,”,
“Option”: {
“Name”: “config_refresh_token”,
“Help”: “Already have a token - refresh?”,
“Provider”: “”,
“Default”: true,
“Value”: null,
“Examples”: [
“Value”: “true”,
“Help”: “Yes”,
“Provider”: “”
“Value”: “false”,
“Help”: “No”,
“Provider”: “”
“ShortOpt”: “”,
“Hide”: 0,
“Required”: false,
“IsPassword”: false,
“NoPrefix”: false,
“Advanced”: false,
“Exclusive”: true,
“Sensitive”: false,
“DefaultStr”: “true”,
“ValueStr”: “true”,
“Type”: “bool”
“Error”: “”,
“Result”: “”
Cyberpanel Current Version:
2.3
Build:
5
Current Commit:
83fa3a0aa8dfecae7912d0f17b7ea655210f3bba
Latest Version:
2.3
Latest Build:
5
Latest Commit:
3ffbe1f55159d88bf6d28e3448b3a0853b1eb907
La
Laque #4
Checking all the log I Found that too, it seems the token creating is not working correctly:
[05.13.2024_14-49-33] rclone config dump
[05.13.2024_14-49-33] cWYSE1+e14R0ra82lxnM38aES/UZ+q3a-u nestd8690 rclone config dump
[05.13.2024_14-49-34] Token Not upadate inside. Error: ‘token’
