Docker and CSF Problems
RM
Rana Muhammad Usman Nasir #1
Got to know about this issue from client server.
If anyone on CyberPanel is using Docker and they have also installed CSF. Then I am experiencing various problems.
I’ve installed csf and enabled docker support in csf configurations.
Then I created docker app from CyberPanel, but keep getting 503 error. It turns out that if i remove csf, remove and re-install docker then apps start working.
I’ve seen couple of posts on reddit, stackoverflow having similar problems.
If you want to remove and re-install Docker, read this guide: Debugging Docker Apps Features – Knowledge Base
This is a devloping story as I’ve contacted csf support…
RM
Rana Muhammad Usman Nasir #2
Update 1: It seems that after adding port 8088 to csf docker apps seems to be working.
But in some cases they are still not working as expected.
RM
Rana Muhammad Usman Nasir #3
Update 2:
If I create Docker App, then install CSF, it does not work.
I had to delete docker and re-install docker from cli and start it again.
Then make sure port 8088 and port 5678 is in CSF for TCP_IN and TCP_OUT.
Then created docker app again and it works.
im
impeck #4
If Docker uses custom bridge networks (e.g., br-XXXX) instead of docker0, CSF needs to be configured to avoid conflicts.
1. Identify Active Docker Bridge(s)
Find your active Docker bridge interfaces (starting with br- and in UP state with 172.x.x.x IPs):
ip a
2. Configure CSF
Edit csf.conf:
nano /etc/csf/csf.conf
Set DOCKER_DEVICE to your active Docker bridge(s) (comma-separated if more than one). Remove docker0 if it’s not in use.
DOCKER_DEVICE = "br-61fa586ddd3a" # Example: "br-abc,br-xyz"
Add the same bridge(s) to ETH_DEVICE_SKIP to prevent CSF from interfering with Docker’s traffic management:
ETH_DEVICE_SKIP = "br-61fa586ddd3a" # Same as DOCKER_DEVICE
Save and exit.
3. Allow Docker Network in csf.allow
Ensure the Docker bridge’s subnet is permitted (e.g., 172.18.0.0/16 for br-61fa586ddd3a):
echo "172.18.0.0/16 # Docker bridge network" >> /etc/csf/csf.allow
# Also ensure 127.0.0.1 is in csf.allow
4. Restart Services in Order
This order is crucial to prevent iptables conflicts:
  1. Stop all Docker containers:
    docker stop $(docker ps -aq)
  2. Restart CSF:
    csf -r
  3. Restart Docker service:
    systemctl restart docker
  4. Start your Docker containers:
    docker compose up -d
