1.Use a cronjob to clear /tmp periodically
2.Find out if you are using any other PHP executable other than the lsphp of the version used on site ( usually happens when you add crons with /
3.Find out why your PHP application is creating so many sessions
4. Ask you provider to increase inode limit for /tmp on your VM
