Cyberpanel PHP path problem
Al
Alex #1
Hi great community.
I’ve searched the threads but haven’t found anything that could help me. I’m not very experienced and I’m trying to learn more about Ubuntu. I installed Cyberpanel and everything works except the PHP changes. If I change the php features in the Cyberpanel panel I don’t see them on the site. I did in info.php which tells me the php is in another path.
Configuration File (php.ini) Path /etc/php/8.0/fpm
Loaded Configuration File /etc/php/8.0/fpm/php.ini
Scan this dir for additional .ini files /etc/php/8.0/fpm/conf.d
It shouldn’t be here:
/usr/local/lsws/lsphpXX/etc/php.ini
or in a similar path?
I can’t solve.
Thanks everyone for the help
jo
josephgodwinke #2
Welcome @alebed Happy you are here
Check if you have a different php installed. We recommend you install cyberpanel in a clean installed os (no webservers, no databases, no php, no dns services, no ftp services)
Make sure you are using the correct php on your website manager.
Al
Alex #3
Thanks for Reply… I’ve used a clean installation of Contabo VPS and I’ve installed Cyberpanel at first.
But afterthat the default php path is:
/etc/php/8.0/fpm
If I choose another version of php under site settings nothing change… The strange thnig is that if I change php version under site settings panel, the php changes but the path is always:
/etc/php/XXX/fpm
