Closed WARNING: /usr/local/CyberCP/public/imunify is not a directory (it should be created by the immunify deploy script). UI will not be installed
CH
Carlos Henrique #1
Hello, I have a server with cyberpanel installed where we configure cloudlinux perfectly.
Imunify 360, on the other hand, generates the following error to install:
WARNING: /usr/local/CyberCP/public/imunify is not a directory (it should be created by the immunify deploy script). UI will not be installed.
Not being able to manage immunify through cyberpanel
Current Version:
2.3
Build:
4
Current Commit:
d32d25fa9acd163e5bcffebd05f0dd565710e964
Latest Version:
2.3
Latest Build:
4
Latest Commit:
PS. I’ve already updated the cyberpanel to the latest version, I’ve reinstalled the imunify and the error is the same
CH
Carlos Henrique #3
manage to fix…
the way you reported there does not work, because there is no folder /usr/local/CyberCP/public/imunify
For anyone having the same problem, the way to fix it is:
Go to where you install imunify…
https://myserver.com:8090/firewall/imunify
put the key and ask to install.
When it is running log in as root go to:
cd /usr/local/CyberCP/public/
and create the imunify folder
mkdir immunify
or if you want to do it before installing it is also ok.
