Cyberpanel down! lscpd not running [urgent]
TA
Tengku Amer #1
Hi guys, i need some help. Everytime i need to access my cyberpanel using port https://domain.com:8090, when error keep showing me " This site can’t be reached. refused to connect", so i open ssh then put command “systemctl status lscpd” if lscdp failed i just command “systemctl restart lscpd” then my port https://domain.com:8090 back to the normal but for limited time only, just running around 10 second and then lscpd stop again. i already trying to updated, but still same, Any ideas?
Below is my result when i put command “systemctl status lscpd -l”
[root@uSeR ~]# systemctl status lscpd -l
● lscpd.service - LSCPD Daemon
Loaded: loaded (/etc/systemd/system/lscpd.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Thu 2023-04-06 09:36:12 UTC; 41min ago
Process: 421 ExecStart=/usr/local/lscp/bin/lscpdctrl start (code=exited, status=0/SUCCESS)
Main PID: 505 (code=exited, status=255)
CGroup: /system.slice/lscpd.service
Mar 23 22:42:48 uSeR sudo[120099]: root : TTY=unknown ; PWD=/tmp/lscpd ; USER=root ; COMMAND=/bin/find /home/domain.com/mail.domain.com -type d -exec chmod 0755 {} ;
Mar 23 22:42:48 uSeR sudo[120120]: root : TTY=unknown ; PWD=/tmp/lscpd ; USER=root ; COMMAND=/bin/chown -R -P uSeR3645:uSeR3645 /home/domain.com/mail.domain.com/.[^.]*
Mar 23 22:42:48 uSeR sudo[120123]: root : TTY=unknown ; PWD=/tmp/lscpd ; USER=root ; COMMAND=/bin/chown -R -P uSeR3645:uSeR3645 /home/domain.com/mail.domain.com/*
Mar 23 22:42:48 uSeR sudo[120108]: root : TTY=unknown ; PWD=/tmp/lscpd ; USER=root ; COMMAND=/bin/find /home/domain.com/mail.domain.com -type f -exec chmod 0644 {} ;
Mar 23 22:42:48 uSeR sudo[120125]: root : TTY=unknown ; PWD=/tmp/lscpd ; USER=root ; COMMAND=/bin/chmod 755 /home/domain.com/mail.domain.com
Mar 23 22:42:48 uSeR sudo[120286]: root : TTY=unknown ; PWD=/tmp/lscpd ; USER=root ; COMMAND=/bin/chown uSeR3645:nobody /home/domain.com/mail.domain.com
Mar 29 15:50:17 uSeR lscpdctrl[559419]: [ERROR] lscpd is not running.
Mar 29 15:50:17 uSeR systemd[1]: lscpd.service: control process exited, code=exited status=1
Mar 29 15:50:17 uSeR systemd[1]: Unit lscpd.service entered failed state.
Mar 29 15:50:17 uSeR systemd[1]: lscpd.service failed.
sh
shoaibkk #2
show me tmp directory
TA
Tengku Amer #3
[root@uSeR ~]# dir /tmp
lscpd lshttpd
