Centos 7 ERR_CONNECTION_REFUSED
BP
Bhanu Pratap #1
I am facing difficulties with ssl renewal and when I tried different solution I lost my website. Now nothing is showing up there,
can you guys please help me.
BP
Bhanu Pratap #2
website is bpmc.agency
BP
Bhanu Pratap #4
but how to get my website back
jo
josephgodwinke #6
Is this a fresh installation ? Which server os ?
BP
Bhanu Pratap #7
no it is not fresh installation. it is centos 7
jo
josephgodwinke #8
DNS seems to be the issue. I see you re managing your DNS with cyberpanel. Did you check if on GoDaddy if bpmc.agency dns records resolves to your server ip
Run cyberpanel upgrade and reboot your server.
BP
Bhanu Pratap #9
I upgraded cyberpanel yesterday
BP
Bhanu Pratap #10
what command I should use to reboot the server
jo
josephgodwinke #11
sudo reboot
BP
Bhanu Pratap #12
it says remote side unexpectedly closed network
jo
josephgodwinke #13
Well this usually a vague error from putty but most of the time its caused by a server which is not online. Do you have access to your server manager? Restart your server from there
BP
Bhanu Pratap #14
I tried, but still not getting it back
BP
Bhanu Pratap #15
I tried to add additional ssl on the website but later I deleted it, I think this caused the problem
BP
Bhanu Pratap #16
I tried additional ssl, because default ssl not working from some days and I tried everything. but still problem not solved.
and just because ssl is not working my campaign failed because all of the emails gone in spam, just because of not having ssl cerfitified link
jo
josephgodwinke #17
Contact your server provider to confirm that your server is up
