Using multiple ip addresses for my websites
JA
Joabe Arruda #1
Hello, could someone here inform how I can insert more than one IP in the panel?
I have dedicated IPs for each application, I need to enter an IP for each site, I have not found anywhere on how to do this (if it is possible).
Even I tried some options with command line more unsuccessful. :slight_smile:
Any tips?
jo
josephgodwinke #2
Hello @pryce
Have you seen this
JA
Joabe Arruda #3
Hello how are you? Thanks for reply
I’ve seen yes several examples of settings here, but none worked, I’m starting to believe that the problem is in GCP. It’s crazy to make things happen over there. :slight_smile:
