I got the following error while trying to save to the database through a PHP application I installed on CyberPanel. No such error while on Cpanel hosting. I suggest the error is from the database management system because when I connect to a remote DB on Cpanel, it works without the error
Ooops Database Error: SQLSTATE[22007]: Invalid datetime format: 1366 Incorrect integer value: ‘’ for column
