Problem install CyberPanel ERROR: No matching distribution found for decorator==3.4.0
ya
yunus aslan #1
i’m getting error like this. i test many server centos 7. All Problem install CyberPanel.
Preparing metadata (setup.py) … error
command: /usr/local/CyberPanel/bin/python3 -c ‘import io, os, sys, setuptools, tokenize; sys.argv[0] = ‘"’"’/tmp/pip-install-73rpld6o/decorator_60df90c4769747e087b66afe9ecca405/setup.py’“'”‘; file=’“'”‘/tmp/pip-install-73rpld6o/decorator_60df90c4769747e087b66afe9ecca405/setup.py’“'”‘;f = getattr(tokenize, ‘"’“‘open’”’“‘, open)(file) if os.path.exists(file) else io.StringIO(’”‘“‘from setuptools import setup; setup()’”’“‘);code = f.read().replace(’”‘"’\r\n’“'”‘, ‘"’"’\n’“'”‘);f.close();exec(compile(code, file, ‘"’“‘exec’”’"‘))’ egg_info --egg-base /tmp/pip-pip-egg-info-0ky_ld8i
cwd: /tmp/pip-install-73rpld6o/decorator_60df90c4769747e087b66afe9ecca405/
Complete output (1 lines):
error in decorator setup command: use_2to3 is invalid.
WARNING: Discarding https://files.pythonhosted.org/packages/f3/26/876d492f2394f29401eb652ddfa53dec2bc8721861c7fe0dce1b5d0d2b6a/decorator-3.4.0.tar.gz#sha256=c20b404cbb7ee5cebd506688e0114e3cd76f5ce233805a51f36e1a7988d9d783 (from Links for decorator). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
ERROR: Could not find a version that satisfies the requirement decorator==3.4.0 (from versions: 3.3.1, 3.3.2, 3.3.3, 3.4.0, 3.4.2, 4.0.0, 4.0.1, 4.0.2, 4.0.3, 4.0.4, 4.0.6, 4.0.8, 4.0.9, 4.0.10, 4.0.11, 4.1.0, 4.1.1, 4.1.2, 4.2.1, 4.3.0, 4.3.1, 4.3.2, 4.4.0, 4.4.1, 4.4.2, 5.0.3, 5.0.4, 5.0.5, 5.0.6, 5.0.7, 5.0.8, 5.0.9, 5.1.0, 5.1.1)
pip install --default-timeout=3600 -r /usr/local/requirments.txt has failed for 6 times
Wait for 3 seconds and try again…
Collecting acme==0.21.1
Using cached acme-0.21.1-py2.py3-none-any.whl (68 kB)
Collecting asgiref==3.2.3
Using cached asgiref-3.2.3-py2.py3-none-any.whl (18 kB)
Collecting asn1crypto==0.24.0
Using cached asn1crypto-0.24.0-py2.py3-none-any.whl (101 kB)
Collecting Babel==0.9.6
Using cached Babel-0.9.6.zip (1.9 MB)
Preparing metadata (setup.py) … done
Collecting backports.ssl-match-hostname==3.5.0.1
Using cached backports.ssl_match_hostname-3.5.0.1.tar.gz (5.6 kB)
Collecting bcrypt==3.1.7
Using cached bcrypt-3.1.7-cp34-abi3-manylinux1_x86_64.whl (56 kB)
Collecting boto3==1.9.64
sh
shoaibkk #3
which os you are using?
YY
YYJ #4
I’m encountering the same problem. I’m using Ubuntu 20.04.5. Initially, I tried to use Python 3.8.10 to install CyberPanel, but I received the following error:
Collecting decorator==3.4.0 (from -r /usr/local/requirments.txt (line 15))
Downloading decorator-3.4.0.tar.gz (30 kB)
│ exit code: 1
╰─> [1 lines of output]
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: metadata-generation-failed
Later, I tried to use Python 3.6.15 to install CyberPanel, but I encountered an “ERROR: No matching distribution found” for decorator==3.4.0.
Please assist me with this issue. Thanks.
