Closed Almalinux 8.7 Cyberpanel update problem
fl
florevit.com #1
Almalinux 8.7
epel-release.noarch 8-18.el8 epel latest version with sudo yum update
epel-release.noarch 8-10.el8 epel when upgrade cyberpanel installed back this version
lsphp74-ioncube.x86_64 12.0.5-1.el8.7.4 litespeed cant upgrade dont work olso other packages what need this stay left back
fl
florevit.com #2
this am get and dont works eather
[root@mail ~]# sudo yum update
Last metadata expiration check: 0:50:32 ago on Mon 09 Jan 2023 12:06:35 PM CET.
Error:
Problem: cannot install the best update candidate for package lsphp74-ioncube-10.4.4-1.el8.7.4.x86_64
  • nothing provides lsphp74(api) = %{php_core_api} needed by lsphp74-ioncube-12.0.5-1.el8.7.4.x86_64
  • nothing provides lsphp74(zend-abi) = %{php_zend_api} needed by lsphp74-ioncube-12.0.5-1.el8.7.4.x86_64
    (try to add ‘–skip-broken’ to skip uninstallable packages or ‘–nobest’ to use not only best candidate packages)
    [root@mail ~]#
fl
florevit.com #3
CyberPanel only works with AlamLinux 8.3/8.4 only. finaly some give answer in forum
