My subdomain only index page works but others all page not works
IM
IMRAN #1
test.maindomain works
but test.maindomain/contact page not works
please help me
jo
josephgodwinke #2
Welcome @imranbru Happy you are here
On the CyberPanel dashboard go to Websites → test.maindomain → File Manager → Fix Permissions
Post the error you are getting. Post a screenshot here
jo
josephgodwinke #4
Is this a Laravel app or Codeigniter app?
Also post your .htaccess
IM
IMRAN #5
this is laravel app
my .htaccess is
Options -MultiViews -Indexes
RewriteEngine On
# Handle Authorization Header
RewriteCond %{HTTP:Authorization} .
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
# Redirect Trailing Slashes If Not A Folder...
RewriteCond %{REQUEST_URI} (.+)/$
RewriteRule ^ %1 [L,R=301]
# Handle Front Controller...
RewriteRule ^ index.php [L]
IM
IMRAN #7
I have tried, that’s not worked
jo
josephgodwinke #8
Sorry i have several laravel applications that work out of the box with those steps. I believe the best way the installation works is if you put the app folder out of your public_html or where you are serving your public files e.g.
  1. Create https://demo.devbap.com as a proper website or a child domain whatever you prefer
  2. For this example - Set the website root to /home/devbap.com/demo
  3. Upload all public files to path above
  4. Create a directory /home/devbap.com/app and upload or rsync from a cloud drive all your other laravel folders and files here
  5. Make the directories writeable and change a few paths in /home/devbap.com/demo/index.php
<?php
use Illuminate\Contracts\Http\Kernel;
use Illuminate\Http\Request;
define('LARAVEL_START', microtime(true));
| Check If The Application Is Under Maintenance
| If the application is in maintenance / demo mode via the "down" command
| we will load this file so that any pre-rendered content can be shown
| instead of starting the framework, which could cause an exception.
if (file_exists($maintenance = __DIR__.'/../storage/framework/maintenance.php')) {
    require $maintenance;
| Register The Auto Loader
| Composer provides a convenient, automatically generated class loader for
| this application. We just need to utilize it! We'll simply require it
| into the script here so we don't need to manually load our classes.
require __DIR__.'/../app/vendor/autoload.php';
| Run The Application
| Once we have the application, we can handle the incoming request using
| the application's HTTP kernel. Then, we will send the response back
| to this client's browser, allowing them to enjoy our application.
$app = require_once __DIR__.'/../app/bootstrap/app.php';
$kernel = $app->make(Kernel::class);
$response = $kernel->handle(
    $request = Request::capture()
)->send();
$kernel->terminate($request, $response);
This assumes your website works locally with all routes working. Consider using artisan to clear route and view cache.
IM
IMRAN #9
that’s not worked. just show me homepage well, you can check in live
jo
josephgodwinke #10
Post your routes here
IM
IMRAN #11
same website host in main domain this works fine, you can check devbap.com
jo
josephgodwinke #12
Are there any logs in your main error log for this subdomain website?
IM
IMRAN #13
no, there is no log error
jo
josephgodwinke #14
Here did you delete the website and follow the steps I gave.
