Cannot load module 'redis' because required module 'json' is not loaded in Unknown on line 0
JS
Jesus Segnini #1
Hello, I am getting this error while i try to run wp command on terminal. Also, phpmyadmin doesnt works and i thing is related with default lsphp
JS
Jesus Segnini #3
Thanks for your reply, there is no json.ini at this folder but extension is marked as installed in dashboard. Tryed disabling and reenabling it but nothing.
jo
josephgodwinke #4
What is the error you are getting? Post screenshot here kindly
