Create Website is not loading and many other features not working
Fu
Fuel #1
Help me out.
I’m running a 6 Core / 16 GB Server with Centos 7
This is fresh installation with nothing else installed.
LSWS wasnt running so I went to SSH and tried systemctl start lsws
and get this
** (pkttyagent:7784): WARNING **: 12:21:17.872: Unable to register authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Cannot determine user of subject
Error registering authentication agent: GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed: Cannot determine user of subject (polkit-error-quark, 0)
for which I used : Polkit error - GDBus.Error:org.freedesktop.PolicyKit1.Error.Failed
Everything else is loading except the things I have listed under.
Main Menu
Wordpress
Deploy Wordpress - Doesnt open. keeps on loading but nothing.
Configure Plugins - Doesnt open. keeps on loading but nothing.
Restore Backups - Doesnt open. keeps on loading but nothing.
Remote Backup - Doesnt open. keeps on loading but nothing.
Websites
Create Website - Doesnt open. keeps on loading but nothing.
Email
Email Debugger - Doesnt open. keeps on loading but nothing.
Root File Manager - Doesnt open. keeps on loading but nothing.
CYBERPANEL MAIN LOG FILE
File was empty
ERROR LOGS
2022-12-07 13:18:34.056590 [ERROR] [7850] Failed to generate the real time report!
2022-12-07 13:25:00.082900 [ERROR] [8194] Failed to generate the real time report!
2022-12-07 13:25:00.083122 [ERROR] [8189] Failed to generate the real time report!
2022-12-07 13:25:01.084868 [ERROR] [8192] Failed to generate the real time report!
2022-12-07 13:25:01.084871 [ERROR] [8191] Failed to generate the real time report!
2022-12-07 13:25:01.084871 [ERROR] [8193] Failed to generate the real time report!
2022-12-07 13:25:01.084881 [ERROR] [8190] Failed to generate the real time report!
2022-12-07 13:25:01.085147 [ERROR] [8189] Failed to generate the real time report!
2022-12-07 13:25:01.085220 [ERROR] [8194] Failed to generate the real time report!
2022-12-07 13:25:02.087015 [ERROR] [8190] Failed to generate the real time report!
2022-12-07 13:25:02.087015 [ERROR] [8193] Failed to generate the real time report!
2022-12-07 13:25:02.087037 [ERROR] [8191] Failed to generate the real time report!
2022-12-07 13:25:02.087434 [ERROR] [8189] Failed to generate the real time report!
2022-12-07 13:25:02.087497 [ERROR] [8194] Failed to generate the real time report!
2022-12-07 13:25:02.087879 [ERROR] [8192] Failed to generate the real time report!
2022-12-07 13:25:03.089275 [ERROR] [8194] Failed to generate the real time report!
2022-12-07 13:25:03.089275 [ERROR] [8191] Failed to generate the real time report!
2022-12-07 13:25:03.089328 [ERROR] [8190] Failed to generate the real time report!
2022-12-07 13:25:03.089368 [ERROR] [8189] Failed to generate the real time report!
2022-12-07 13:25:03.089496 [ERROR] [8193] Failed to generate the real time report!
2022-12-07 13:25:03.089614 [ERROR] [8192] Failed to generate the real time report!
2022-12-07 13:25:04.091453 [ERROR] [8192] Failed to generate the real time report!
2022-12-07 13:25:04.091692 [ERROR] [8190] Failed to generate the real time report!
2022-12-07 13:25:04.092070 [ERROR] [8193] Failed to generate the real time report!
2022-12-07 13:25:04.092147 [ERROR] [8191] Failed to generate the real time report!
2022-12-07 13:25:04.092164 [ERROR] [8194] Failed to generate the real time report!
2022-12-07 13:25:04.092194 [ERROR] [8189] Failed to generate the real time report!
2022-12-07 13:25:05.093792 [ERROR] [8190] Failed to generate the real time report!
2022-12-07 13:25:05.093958 [ERROR] [8191] Failed to generate the real time report!
2022-12-07 13:25:05.093995 [ERROR] [8193] Failed to generate the real time report!
2022-12-07 13:25:05.094057 [ERROR] [8192] Failed to generate the real time report!
2022-12-07 13:25:05.094131 [ERROR] [8194] Failed to generate the real time report!
2022-12-07 13:25:05.094188 [ERROR] [8189] Failed to generate the real time report!
2022-12-07 13:25:06.095921 [ERROR] [8191] Failed to generate the real time report!
2022-12-07 13:25:06.095929 [ERROR] [8194] Failed to generate the real time report!
2022-12-07 13:25:06.096052 [ERROR] [8190] Failed to generate the real time report!
2022-12-07 13:25:06.096082 [ERROR] [8189] Failed to generate the real time report!
2022-12-07 13:25:06.096248 [ERROR] [8192] Failed to generate the real time report!
2022-12-07 13:25:06.096274 [ERROR] [8193] Failed to generate the real time report!
2022-12-07 13:25:07.098077 [ERROR] [8190] Failed to generate the real time report!
2022-12-07 13:25:07.098079 [ERROR] [8191] Failed to generate the real time report!
2022-12-07 13:25:07.098134 [ERROR] [8194] Failed to generate the real time report!
2022-12-07 13:25:07.098169 [ERROR] [8192] Failed to generate the real time report!
2022-12-07 13:25:07.098226 [ERROR] [8189] Failed to generate the real time report!
2022-12-07 13:25:07.098235 [ERROR] [8193] Failed to generate the real time report!
2022-12-07 13:25:08.100376 [ERROR] [8192] Failed to generate the real time report!
2022-12-07 13:25:08.100384 [ERROR] [8189] Failed to generate the real time report!
2022-12-07 13:25:08.100418 [ERROR] [8190] Failed to generate the real time report!
2022-12-07 13:25:08.100419 [ERROR] [8194] Failed to generate the real time report!
2022-12-07 13:25:08.100561 [ERROR] [8193] Failed to generate the real time report!
2022-12-07 13:25:08.100917 [ERROR] [8191] Failed to generate the real time report!
MODSECURITY AUDIT LOGS
tail: cannot open ‘/usr/local/lsws/logs/auditmodsec.log’ for reading: No such file or directory
RSPAMD - Doesnt open. keeps on loading but nothing.
and after sometime all functions start giving 503 error.
jo
josephgodwinke #2
Welcome @fuel Happy you are here
Not a solution but a workaround.
Just install in Ubuntu 20.04 LTS or AlmaLimux 8.4 x64bit. Do not try Centos 7/8 you will run into many issues. This is just my opnion through experience.
Fu
Fuel #3
I understand your concern. I have Cyberpanel installed last month (maybe 16 or 17th Nov 2022) thats working fine on another machine the same vps host.
This installation above is on another machine on same vps host. only thing changed in Cyberpanel version. I suppose this is new one.
and if everyone starts skipping errors and centos then how do you expect CyberPanel to grow?
whats your exp with Alma and Ubuntu … btw alma is last to get updates I suppose to know that.
jo
josephgodwinke #4
Ubuntu 20.04 LTS is the os with least issues. I have several servers running this os i hardly fix anything after an upgrade or user action.
You are getting all the other errors after this because lsws service is not up and that is OLS your webserver, Without it nothing runs properly even lscpd
I had CentOs 7 servers and i had issues almost every week. I replaced them entirely with AlmaLinux 8 and i also hardly fix anything after an upgrade or user action.
Fu
Fuel #5
so, what linux would you suggest? Ubuntu or Alma? and are you sure these errors won’t happen on those?
jo
josephgodwinke #6
Obviously if your server comes with preinstalled software from your provider that may hinder or block OLS for any particular reason then i cannot guarantee cyberpanel will run error free.
Use baremetal servers or VPS providers who support cyberpanel.
I always use Ubuntu 20.04 LTS if given the choice by my clients.
Fu
Fuel #7
The VPS provider installs fresh OS on demand. So its ubuntu 20.04 LTS over Alma then
Fu
Fuel #8
they are currently offering
debian/opensuse/centos and ubuntu
Ubuntu Server 20.x LTS 64-bit
Ubuntu Server 18.x LTS 64-bit
Ubuntu Server 16.x LTS 64-bit
jo
josephgodwinke #9
Fu
Fuel #10
ok i have asked the support to install ubuntu. hopefully we’ll have better result with cyberpanel.
