al
I can't upgrade my cyberpanel using terminal or ssh? Please help
jo
Hello @BOOBA Happy you are here
This is an issue with your ISP. Kindly use a VPN or change networks and try again
If you believe the port 22 is blocked by firewalld use VNC to log into your VPS and stop firewalld using command systemctl stop firewalld
If you have any other firewalls disable them too just to be sure
