SnappyMail not on default port number won't load
Mv
Mike van Eckendonk #1
Hey team,
I changed the default port number to another to run CyberPanel on a domain and use Cloudflare.
Now, SnappyMail won’t load anymore. How can I fix this issue?
CE
Cristian Eslava Suárez #2
Hi, any luck with this issue? SnappyMail won’t load and WP do no send emails.
Mv
Mike van Eckendonk #3
Yep, was quite easy to solve.
Create a domain, webmail.domain.com
Edit the rewrite rules and make it look like this.
## Rewrite Rules Added by CyberPanel Rewrite Rule Generator
RewriteEngine On
RewriteCond %{HTTPS}  !=on
RewriteRule ^/?(.*) https://%{SERVER_NAME}/$1 [R,L]
### End CyberPanel Generated Rules.
RewriteEngine on
RewriteCond %{QUERY_STRING} ^$
RewriteRule ^$ https://switch-xxx.domain.com/snappymail? [R=301,L,NC]
This works if you have the config without port 8090.
CE
Cristian Eslava Suárez #4
Thanks for sharing.
That didn´t solve my problem. The problem was rocket loader on cloudflare. I desactivated it and now snappymail is loading.
Mv
Mike van Eckendonk #5
Cloudflare will give issues with these rewrite rules
