SSL certification does not work
DT
Digital Tasweq #1
SSL not working ! error 404
I am not able to issued SSL for my website and I think the error is 404 can anyone help me with this issue please?
[10.31.2022_11-13-39] [Error:createWebsite] Websites matching query does not exist.
[10.31.2022_11-14-09] Status Code: Unknown for: http://www.localhost/.well-known/acme-challenge/localhost. Error: HTTPConnectionPool(host='www.localhost', port=80): Max retries exceeded with url: /.well-known/acme-challenge/localhost (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f5b6a80cd30>: Failed to establish a new connection: [Errno -2] Name or service not known'))
[10.31.2022_11-14-09] Status Code: 200 for: http://localhost/.well-known/acme-challenge/localhost
[10.31.2022_11-14-25] /root/.acme.sh/acme.sh --issue -d localhost -d www.localhost --cert-file /etc/letsencrypt/live/localhost/cert.pem --key-file /etc/letsencrypt/live/localhost/privkey.pem --fullchain-file /etc/letsencrypt/live/localhost/fullchain.pem -w /usr/local/lsws/Example/html -k ec-256 --force --server letsencrypt
[10.31.2022_11-14-52] Failed to obtain SSL for: localhost and: www.localhost
[10.31.2022_11-14-52] Trying to obtain SSL for: localhost
[10.31.2022_11-15-12] Failed to obtain SSL, issuing self-signed SSL for: localhost
[10.31.2022_11-15-13] Connection unexpectedly closed
[10.31.2022_11-15-13] Self signed SSL issued for localhost.
[10.31.2022_11-23-54] Status Code: 404 for: http://www.souqsquare.com/.well-known/acme-challenge/souqsquare.com. Error: <html>
<head><title>404 Not Found</title></head>
<body>
<center><h1>404 Not Found</h1></center>
<hr><center>openresty</center>
</body>
</html>
AH
Abdul Haseeb #2
Can you show htaccess rules?
tb
tbaldur #3
Create the DNS for www.souqsquare.com, you perhaps don’t have for the “www” part.
or
Check for missing .well-known on your vhost config. If you are using cyberpanel for a long time and upgraded, this is the most likely.
or
Manually run the command without www:
/root/.acme.sh/acme.sh --issue -d souqsquare.com --cert-file /etc/letsencrypt/live/souqsquare.com/cert.pem --key-file /etc/letsencrypt/live/souqsquare.com/privkey.pem --fullchain-file /etc/letsencrypt/live/souqsquare.com/fullchain.pem -w /usr/local/lsws/Example/html --force --debug
DT
Digital Tasweq #4
Please check the file
Thank you
BEGIN WordPress
The directives (lines) between “BEGIN WordPress” and “END WordPress” are
dynamically generated, and should only be modified via WordPress filters.
Any changes to the directives between these markers will be overwritten.
RewriteEngine On RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}] RewriteBase / RewriteRule ^index\.php$ - [L] RewriteCond %{REQUEST_FILENAME} !-f RewriteCond %{REQUEST_FILENAME} !-d RewriteRule . /index.php [L]
END WordPress
DT
Digital Tasweq #5
I have tried the 3 solutions and none of them works
tb
tbaldur #6
The last one, post here the output of the command please
DT
Digital Tasweq #7
root@vps:~# /root/.acme.sh/acme.sh --issue -d souqsquare.com --cert-file /etc/letsencrypt/live/souqsquare.com/cert.pem --key-file /etc/letsencrypt/live/souqsquare.com/privkey.pem --fullchain-file /etc/letsencrypt/live/souqsquare.com/fullchain.pem -w /usr/local/lsws/Example/html --force --debug
[Wed 02 Nov 2022 11:26:12 AM UTC] Lets find script dir.
[Wed 02 Nov 2022 11:26:12 AM UTC] _SCRIPT_='/root/.acme.sh/acme.sh'
[Wed 02 Nov 2022 11:26:12 AM UTC] _script='/root/.acme.sh/acme.sh'
[Wed 02 Nov 2022 11:26:12 AM UTC] _script_home='/root/.acme.sh'
[Wed 02 Nov 2022 11:26:12 AM UTC] Using config home:/root/.acme.sh
https://github.com/acmesh-official/acme.sh
v3.0.5
[Wed 02 Nov 2022 11:26:13 AM UTC] Running cmd: issue
[Wed 02 Nov 2022 11:26:13 AM UTC] _main_domain='souqsquare.com'
[Wed 02 Nov 2022 11:26:13 AM UTC] _alt_domains='no'
[Wed 02 Nov 2022 11:26:13 AM UTC] Using config home:/root/.acme.sh
[Wed 02 Nov 2022 11:26:13 AM UTC] default_acme_server='https://acme-v02.api.letsencrypt.org/directory'
[Wed 02 Nov 2022 11:26:13 AM UTC] ACME_DIRECTORY='https://acme-v02.api.letsencrypt.org/directory'
[Wed 02 Nov 2022 11:26:13 AM UTC] DOMAIN_PATH='/root/.acme.sh/souqsquare.com'
[Wed 02 Nov 2022 11:26:13 AM UTC] Le_NextRenewTime
[Wed 02 Nov 2022 11:26:13 AM UTC] Using ACME_DIRECTORY: https://acme-v02.api.letsencrypt.org/directory
[Wed 02 Nov 2022 11:26:13 AM UTC] _init api for server: https://acme-v02.api.letsencrypt.org/directory
[Wed 02 Nov 2022 11:26:13 AM UTC] GET
[Wed 02 Nov 2022 11:26:13 AM UTC] url='https://acme-v02.api.letsencrypt.org/directory'
[Wed 02 Nov 2022 11:26:13 AM UTC] timeout=
[Wed 02 Nov 2022 11:26:13 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g '
[Wed 02 Nov 2022 11:26:19 AM UTC] ret='0'
[Wed 02 Nov 2022 11:26:19 AM UTC] ACME_KEY_CHANGE='https://acme-v02.api.letsencrypt.org/acme/key-change'
[Wed 02 Nov 2022 11:26:19 AM UTC] ACME_NEW_AUTHZ
[Wed 02 Nov 2022 11:26:19 AM UTC] ACME_NEW_ORDER='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Wed 02 Nov 2022 11:26:19 AM UTC] ACME_NEW_ACCOUNT='https://acme-v02.api.letsencrypt.org/acme/new-acct'
[Wed 02 Nov 2022 11:26:19 AM UTC] ACME_REVOKE_CERT='https://acme-v02.api.letsencrypt.org/acme/revoke-cert'
[Wed 02 Nov 2022 11:26:19 AM UTC] ACME_AGREEMENT='https://letsencrypt.org/documents/LE-SA-v1.3-September-21-2022.pdf'
[Wed 02 Nov 2022 11:26:19 AM UTC] ACME_NEW_NONCE='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
[Wed 02 Nov 2022 11:26:20 AM UTC] Using CA: https://acme-v02.api.letsencrypt.org/directory
[Wed 02 Nov 2022 11:26:20 AM UTC] _on_before_issue
[Wed 02 Nov 2022 11:26:20 AM UTC] _chk_main_domain='souqsquare.com'
[Wed 02 Nov 2022 11:26:20 AM UTC] _chk_alt_domains
[Wed 02 Nov 2022 11:26:20 AM UTC] Le_LocalAddress
[Wed 02 Nov 2022 11:26:20 AM UTC] d='souqsquare.com'
[Wed 02 Nov 2022 11:26:20 AM UTC] Check for domain='souqsquare.com'
[Wed 02 Nov 2022 11:26:20 AM UTC] _currentRoot='/usr/local/lsws/Example/html'
[Wed 02 Nov 2022 11:26:20 AM UTC] _saved_account_key_hash is not changed, skip register account.
[Wed 02 Nov 2022 11:26:20 AM UTC] Read key length:2048
[Wed 02 Nov 2022 11:26:20 AM UTC] _createcsr
[Wed 02 Nov 2022 11:26:20 AM UTC] Single domain='souqsquare.com'
[Wed 02 Nov 2022 11:26:21 AM UTC] Getting domain auth token for each domain
[Wed 02 Nov 2022 11:26:21 AM UTC] d
[Wed 02 Nov 2022 11:26:21 AM UTC] url='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Wed 02 Nov 2022 11:26:21 AM UTC] payload='{"identifiers": [{"type":"dns","value":"souqsquare.com"}]}'
[Wed 02 Nov 2022 11:26:21 AM UTC] RSA key
[Wed 02 Nov 2022 11:26:21 AM UTC] HEAD
[Wed 02 Nov 2022 11:26:21 AM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-nonce'
[Wed 02 Nov 2022 11:26:22 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g  -I  '
[Wed 02 Nov 2022 11:26:27 AM UTC] _ret='0'
[Wed 02 Nov 2022 11:26:27 AM UTC] POST
[Wed 02 Nov 2022 11:26:27 AM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/new-order'
[Wed 02 Nov 2022 11:26:27 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g '
[Wed 02 Nov 2022 11:26:33 AM UTC] _ret='0'
[Wed 02 Nov 2022 11:26:33 AM UTC] code='201'
[Wed 02 Nov 2022 11:26:33 AM UTC] Le_LinkOrder='https://acme-v02.api.letsencrypt.org/acme/order/802522782/140249742227'
[Wed 02 Nov 2022 11:26:33 AM UTC] Le_OrderFinalize='https://acme-v02.api.letsencrypt.org/acme/finalize/802522782/140249742227'
[Wed 02 Nov 2022 11:26:33 AM UTC] url='https://acme-v02.api.letsencrypt.org/acme/authz-v3/171529726797'
[Wed 02 Nov 2022 11:26:34 AM UTC] payload
[Wed 02 Nov 2022 11:26:34 AM UTC] POST
[Wed 02 Nov 2022 11:26:34 AM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/authz-v3/171529726797'
[Wed 02 Nov 2022 11:26:34 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g '
[Wed 02 Nov 2022 11:26:39 AM UTC] _ret='0'
[Wed 02 Nov 2022 11:26:39 AM UTC] code='200'
[Wed 02 Nov 2022 11:26:40 AM UTC] d='souqsquare.com'
[Wed 02 Nov 2022 11:26:40 AM UTC] Getting webroot for domain='souqsquare.com'
[Wed 02 Nov 2022 11:26:40 AM UTC] _w='/usr/local/lsws/Example/html'
[Wed 02 Nov 2022 11:26:40 AM UTC] _currentRoot='/usr/local/lsws/Example/html'
[Wed 02 Nov 2022 11:26:40 AM UTC] entry='"type":"http-01","status":"pending","url":"https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q","token":"Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0"'
[Wed 02 Nov 2022 11:26:40 AM UTC] token='Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0'
[Wed 02 Nov 2022 11:26:40 AM UTC] uri='https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q'
[Wed 02 Nov 2022 11:26:40 AM UTC] keyauthorization='Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0.Wq9afiKNgop421vDUZfX9aFtfnEYCm8zaIDCvS4Y_i8'
[Wed 02 Nov 2022 11:26:40 AM UTC] dvlist='souqsquare.com#Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0.Wq9afiKNgop421vDUZfX9aFtfnEYCm8zaIDCvS4Y_i8#https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q#http-01#/usr/local/lsws/Example/html'
[Wed 02 Nov 2022 11:26:40 AM UTC] vlist='souqsquare.com#Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0.Wq9afiKNgop421vDUZfX9aFtfnEYCm8zaIDCvS4Y_i8#https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q#http-01#/usr/local/lsws/Example/html,'
[Wed 02 Nov 2022 11:26:40 AM UTC] ok, let's start to verify
[Wed 02 Nov 2022 11:26:41 AM UTC] Verifying: souqsquare.com
[Wed 02 Nov 2022 11:26:41 AM UTC] d='souqsquare.com'
[Wed 02 Nov 2022 11:26:41 AM UTC] keyauthorization='Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0.Wq9afiKNgop421vDUZfX9aFtfnEYCm8zaIDCvS4Y_i8'
[Wed 02 Nov 2022 11:26:41 AM UTC] uri='https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q'
[Wed 02 Nov 2022 11:26:41 AM UTC] _currentRoot='/usr/local/lsws/Example/html'
[Wed 02 Nov 2022 11:26:41 AM UTC] wellknown_path='/usr/local/lsws/Example/html/.well-known/acme-challenge'
[Wed 02 Nov 2022 11:26:41 AM UTC] writing token:Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0 to /usr/local/lsws/Example/html/.well-known/acme-challenge/Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0
[Wed 02 Nov 2022 11:26:41 AM UTC] Changing owner/group of .well-known to root:root
[Wed 02 Nov 2022 11:26:41 AM UTC] url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q'
[Wed 02 Nov 2022 11:26:41 AM UTC] payload='{}'
[Wed 02 Nov 2022 11:26:41 AM UTC] POST
[Wed 02 Nov 2022 11:26:41 AM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q'
[Wed 02 Nov 2022 11:26:41 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g '
[Wed 02 Nov 2022 11:26:47 AM UTC] _ret='0'
[Wed 02 Nov 2022 11:26:47 AM UTC] code='200'
[Wed 02 Nov 2022 11:26:47 AM UTC] trigger validation code: 200
[Wed 02 Nov 2022 11:26:47 AM UTC] Pending, The CA is processing your order, please just wait. (1/30)
[Wed 02 Nov 2022 11:26:47 AM UTC] sleep 2 secs to verify again
[Wed 02 Nov 2022 11:26:50 AM UTC] checking
[Wed 02 Nov 2022 11:26:50 AM UTC] url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q'
[Wed 02 Nov 2022 11:26:50 AM UTC] payload
[Wed 02 Nov 2022 11:26:50 AM UTC] POST
[Wed 02 Nov 2022 11:26:50 AM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q'
[Wed 02 Nov 2022 11:26:50 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g '
[Wed 02 Nov 2022 11:26:56 AM UTC] _ret='0'
[Wed 02 Nov 2022 11:26:56 AM UTC] code='200'
[Wed 02 Nov 2022 11:26:56 AM UTC] souqsquare.com:Verify error:2a02:4780:8:958:0:259d:190a:1: Invalid response from http://souqsquare.com/.well-known/acme-challenge/Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0: 404
[Wed 02 Nov 2022 11:26:56 AM UTC] Debug: get token url.
[Wed 02 Nov 2022 11:26:56 AM UTC] GET
[Wed 02 Nov 2022 11:26:56 AM UTC] url='http://souqsquare.com/.well-known/acme-challenge/Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0'
[Wed 02 Nov 2022 11:26:56 AM UTC] timeout=1
[Wed 02 Nov 2022 11:26:56 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g  --connect-timeout 1'
[Wed 02 Nov 2022 11:27:01 AM UTC] Please refer to https://curl.haxx.se/libcurl/c/libcurl-errors.html for error code: 28
[Wed 02 Nov 2022 11:27:01 AM UTC] ret='28'
[Wed 02 Nov 2022 11:27:01 AM UTC] Debugging, skip removing: /usr/local/lsws/Example/html/.well-known/acme-challenge/Dfnqoddfa_fLe-Ohz7i263qmklKSHvHuZj4HElRZCt0
[Wed 02 Nov 2022 11:27:02 AM UTC] pid
[Wed 02 Nov 2022 11:27:02 AM UTC] No need to restore nginx, skip.
[Wed 02 Nov 2022 11:27:02 AM UTC] _clearupdns
[Wed 02 Nov 2022 11:27:02 AM UTC] dns_entries
[Wed 02 Nov 2022 11:27:02 AM UTC] skip dns.
[Wed 02 Nov 2022 11:27:02 AM UTC] _on_issue_err
[Wed 02 Nov 2022 11:27:02 AM UTC] Please add '--debug' or '--log' to check more details.
[Wed 02 Nov 2022 11:27:02 AM UTC] See: https://github.com/acmesh-official/acme.sh/wiki/How-to-debug-acme.sh
[Wed 02 Nov 2022 11:27:02 AM UTC] url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q'
[Wed 02 Nov 2022 11:27:02 AM UTC] payload='{}'
[Wed 02 Nov 2022 11:27:02 AM UTC] POST
[Wed 02 Nov 2022 11:27:02 AM UTC] _post_url='https://acme-v02.api.letsencrypt.org/acme/chall-v3/171529726797/ovHA_Q'
[Wed 02 Nov 2022 11:27:02 AM UTC] _CURL='curl --silent --dump-header /root/.acme.sh/http.header  -L  -g '
[Wed 02 Nov 2022 11:27:08 AM UTC] _ret='0'
[Wed 02 Nov 2022 11:27:08 AM UTC] code='400'
[Wed 02 Nov 2022 11:27:08 AM UTC] Diagnosis versions:
openssl:openssl
OpenSSL 1.1.1f  31 Mar 2020
apache:
apache doesn't exist.
nginx:
nginx doesn't exist.
socat:
socat by Gerhard Rieger and contributors - see www.dest-unreach.org
socat version 1.7.3.3 on Oct 26 2019 17:42:04
   running on Linux version #1 SMP Tue Aug 25 11:59:26 MSK 2020, release 5.4.0, machine x86_64
features:
  #define WITH_STDIO 1
  #define WITH_FDNUM 1
  #define WITH_FILE 1
  #define WITH_CREAT 1
  #define WITH_GOPEN 1
  #define WITH_TERMIOS 1
  #define WITH_PIPE 1
  #define WITH_UNIX 1
  #define WITH_ABSTRACT_UNIXSOCKET 1
  #define WITH_IP4 1
  #define WITH_IP6 1
  #define WITH_RAWIP 1
  #define WITH_GENERICSOCKET 1
  #define WITH_INTERFACE 1
  #define WITH_TCP 1
  #define WITH_UDP 1
  #define WITH_SCTP 1
  #define WITH_LISTEN 1
  #define WITH_SOCKS4 1
  #define WITH_SOCKS4A 1
  #define WITH_PROXY 1
  #define WITH_SYSTEM 1
  #define WITH_EXEC 1
  #undef WITH_READLINE
  #define WITH_TUN 1
  #define WITH_PTY 1
  #define WITH_OPENSSL 1
  #undef WITH_FIPS
  #define WITH_LIBWRAP 1
  #define WITH_SYCLS 1
  #define WITH_FILAN 1
  #define WITH_RETRY 1
  #define WITH_MSGLEVEL 0 /*debug*/
DT
Digital Tasweq #8
# BEGIN WordPress
# The directives (lines) between "BEGIN WordPress" and "END WordPress" are
# dynamically generated, and should only be modified via WordPress filters.
# Any changes to the directives between these markers will be overwritten.
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
</IfModule>
# END WordPress
