Elementor Pro "Custom Code" 403 Error
of
ofm1990 #1
Hello if you are having problems with the “Custom Code” of Elementor Pro, I inform you that after a lot of research, I found the problem related to ModSecurity used by Cyberpanel, it is a false positive and it is already under review by the OWASP team:
There is still no solution, if not to disable the rule.
If anyone here comes up with a better solution, please help.
jo
josephgodwinke #3
Hello @sochun2424
do not recommend modsecurity. Development stopped years ago. Kindly use an alternative WAF. I recommend CloudFlare for your website, Imunify for your server
For wordpress websites use WordFence premium, Sucuri or BPS. They all work like a charm
of
ofm1990 #4
@josephgodwinke Did you take a look at the link I sent?
Seems like it’s in constant development, 4 will be released soon, using Sucuri on more than 30 sites is a headache, better to have a solution on the panel/server.
